Thread: PC modders - Temp Gauges?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default PC modders - Temp Gauges?
    What's the best way to lengthen the temp probes?
    Even if not on a PC, guessing there like most probes, 2 wires that can be lengthened is that right?
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    ive got a synthe fan controller that can display the temps and can with the probes but i dont bother with it as speed fan tells you all you need to know
    Watercooling FTW
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    It's PC ones I've used but I'm fitting to the car... That's why I need the probes lengthening, there only 50cm at min.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    I have the same ones on my pc, If you extend the wires too long it will effect the accuracy of the gauge, the amount will be determined by the the resistance caused by the longer wire and wire connections, but we are only talking very small amounts.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Cheers, what wire can be used?
    Accuraccy not an issue to within a few degrees, only putting a probe before the MAF and one in the cam breather pipe before the catch can... Should have bought 3 to butcher a tester...
    Aug 2009
    Trim : SRI
    Mileage : 50000
    I added about 30cm using speaker cable and it made no difference.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Awesome thanks again...
  1. Speed Modders beware this will get you.!!
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 12:46
  2. gauges???
    By damadom in forum Petrol Engine related
    Last Post: 8th September 2009, 17:30
  3. Additional gauges
    By greg_t in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 18:51
  4. Modders Anonymous!
    By Robbie69 in forum The 'Off Topic' room
    Last Post: 11th December 2008, 13:38
  5. pods + gauges HELP
    By V6rit in forum Styling
    Last Post: 5th April 2008, 15:42
