Results 1 to 10 of 11
Thread: Where do i plug in my tuning box on a 1.9 CDTI 8v 120
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Red face Where do i plug in my tuning box on a 1.9 CDTI 8v 120
    As above, i need to know were to plug this in, as ive looked, and cant seem to see it to well, ive took the black cover of top of engine.
    Its a 120bhp 8v 1.9
    I bought second hand box hence why i have no idea as it has no instructions lol
    Thanks in advance.
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Depends on the type of tuning box i think, but it will probably plug into the common rail across the top of the engine - take the cover off and the connection is on the righthand side of the engine
    scottish region
    Look in the how 2 section
    Full Member coldo's Avatar
    Scotland
    You need to plug it into the rail (and connect it to the battery if the unit needs a power source)
    The rail is down the back of the engine right next to the EGR... Proper paint to get to the first time.
    Make sure and conect it round the right way...! if you put in on back to fron the engine will rev up to about 2k and not be responcive to the throtal... it will also log a fault code. Swapping it round will sort it all out if that happens...
    This was the connector down the back of my 1.9 120 in my astra...
    Hope that helps
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Quote Originally Posted by Dai69 View Post
    Its got 2 plugs on it, 3 pin ones i belive them to be.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Ohh right, nice one i was on the right tracks then, where does the other plug go? As i have 2? And how do you get them plugs out? as i tried and was proving difficult lol
    Thanks again,
    Scotland
    They have a clip on top which you press down and it should come right off...
    The other plug may be for the boost sensor or the maf.. Not 100% sure...
    What box have you bought?
    Nr Welshpool
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    One plugs into the rail , the plug that you remove to plug the tuning box in goes into the other plug on the box (one is a plug, the other is a socket)
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    So it goes like a daisy chain as such.. just ones male and female so the original one is still there?
    Its a CR Tech on i think got it cheap so gonna give it a wizz
    Scotland
    Yeah.. sounds about right for the connector.. The lead you have has three connectors...On connects to the box and the other two are spare.. You disconect the orignial lead in the car which connects to the mail connector of the tunnign box. The female connector plugs into the rail... All plugs used.. nothing spare!
  1. CDTI 150 3rd Injector Plug fix
    Last Post: 23rd April 2012, 19:10
  2. V6 Cdti glow plug relay
    By Critch in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 16:31
  3. tuning box plug and play?
    By m1ke823146 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2011, 14:18
  4. Tuning Box for 1.9 CDTi 120 (plug & play)
    By Draggon in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 1st February 2009, 18:01
  5. Diesel Tuning UK Tuning Box FOR SALE CDti 150
    By sshooie in forum Parts for sale
    Last Post: 1st April 2008, 16:49
1.9cdti 120 tuning box connection
