Results 1 to 10 of 11
Thread: Front cig lighter dead :( any ideas?
    Regular Member Shogun's Avatar
    Aug 2011
    Default Front cig lighter dead :( any ideas?
    Hey guys, my front cig lighter is just stone dead, I've never needed to use it before but today I bought this fancy iPhone car holder kit that charges it up via the cig lighter,
    Or would do...
    I checked the fuse f22 a green one and its not broken
    and annoyingly the rear lighter works!!
    Anyobe got any ideas at all, many thanks in advance the cars a 2006 signum
    thx guys
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Pop the gear stick gator off and lift out the ashtray, maybe the connector has just come off.
    Regular Member John Bishop's Avatar
    Oct 2010
    Ditto
    Aug 2011
    ok guys will have a mooch in a sec when the weather calms down,
    mines an automatic, simple enough to take apart?
    Oct 2010
    Not sure about an auto
    Aug 2007
    North West
    Trim : SRI With a few added extras
    Engine : 1.9 CDTI 120
    Year : 06
    Take the ashtray insert out then remove the ashtray proper bud, you can just get your fingers round to see if the connector has come adrift
    11 Post(s)
    I take it you're trying it with the ignition switched on?
    Have you tried anything else in the socket to see if that works or not?
    Dec 2011
    Belfast
    this happened to me and it was the connector that had come loose. Just follow what the lads are saying, should be an easy fix
    Regular Member mat_splat's Avatar
    May 2012
    Frimley
    There is a 2nd fuse it could be, check all your 20Amp Slow Burn (Glass/Transp. Plastic Topped) Fuses.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    have you tried to plug something else into it just encase something is up with the iphone charger its self.
  1. Engine dead-after changing injectors - any ideas?
    By Sch3cter in forum Engine & Drivetrain
    Last Post: 8th September 2010, 12:55
  2. When does the front cig lighter power up?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2010, 01:03
  3. cigarette lighter front Vectra C
    By CristianTM in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2008, 18:04
  4. Front cigar lighter
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2008, 23:42
  5. Ciggy lighter dead
    By APJ in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2007, 12:15
