Thread: Aftermarket Headunit
    Essex
    Default Aftermarket Headunit
    Quick question...when an aftermarket headunit is installed in a vectra C what is displayed on the in dash screen when no adapter is used? Is it just blank or does it display the date?
    I know on the vectra b i had to cut a wire to make it display the date permanantly, is this still the case with the vectra c?
    Its an LS so has no on board computer
    Thank you
    Regular Member Ben H's Avatar
    Herts\Beds Border
    The date will go out when you switch the radio on. Don't know if the Vectra has an amplifier in the aerial base, if not you could disconnect the wire for the electric aerial feed of your aftermarket radio as this was the wire in the car which would control the display.
    Going from older Vauxhalls, don't know if would be the same for yours depending if your radio is on CAN bus or not..
    Essex
    its a 53 plate, which I believe means its not CAN bus. Has anyone done this does anyone know if it works?
    Herts\Beds Border
    Yeah, on the earlier Vauxhalls if you simply didn't connect the electric aerial wire (normally blue) the amp in the base of aerial wouldn't switch on & you get no radio. This is why you'd have to cut one of the two wires going into the back of the ISO plug. One wire controls the display, the other the aerial. Don't know if the Vec C works the same.
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    only part of the display i lost once i installed my pioneer was just the radio station part. it still shows date and time at the top of the display plus mines is a 2004 53 plate
    Herts\Beds Border
    God I have my head up my asre this evening, don't think I've actually stopped since I got in from work & Xmas shopping on the way home then I inhaled my dinner!!!
    Sorry, I guess you would lose the radio information wouldn't you!!! That part will be blank but the date & time stays the same.
    I'm going to go & hibernate now, I need sleep!
  1. The pros and cons of an aftermarket headunit
    By cont1204 in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 22:39
  2. Aftermarket headunit wired to battery
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2010, 22:03
  3. Fed up - please help... Aftermarket double din headunit fitting
    By andyfeeny in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2010, 19:42
  4. Aftermarket Headunit
    By mshaw in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2009, 10:28
  5. Vectra Aftermarket Headunit Help
    By jmacp in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2009, 21:35
