Results 1 to 10 of 15
Thread: Z20NET: How can you tell if the Recirc has been blanked off?
    wales
    Default Z20NET: How can you tell if the Recirc has been blanked off?
    Hey,
    As the title says really. What would I be looking for? My car has a dump valve on it, and I really want it gone, but I need to know whether this has been blanked or not!
    TIA
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    stick you head down the back of the engine and look at the turbo where the airbox induction pipe connects to it, just below that on the compressor is the recirc valve and it its there you will have a hose coming off it to the actuator
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Jun 2009
    South Coast
    6 Post(s)
    btw some dump valves are recirculating, some fit in line elsewhere and some can be fitted directly to this aperture on the side of the turbo compressor housing. where is yours currently fitted?
    wales
    hi Nige,
    Thanks for your replies. Mine is located at the front of the engine - off the boost pipe. I'll take a look in the morning/tomorrow evening to see if I can spot what you've mentioned.
    Jun 2009
    South Coast
    6 Post(s)
    the recirc/wastergate are internal on these turbos, but if you look for that it will tell you what you want to know..
    see the pic below, its the round protruding part where vacuum pipe connects, just above the righthand corner of the paper. its held in with three bolts.
    wales
    Fantastic, thanks very much! I'll check it out tomorrow, see what the damage is...
    wales
    Right, I have been out to the car (I can go back out if this picture shows nothing)
    Does this offer any further insight? Or do I need a picture from a different angle/position?
    TIA
    wales
    Hey guys,
    sorry to bump my old thread, but I really want this dump valve off! I have the boost pipe ready to replace but I need to know whether the recirculation valve has been blanked!
    Jun 2009
    South Coast
    6 Post(s)
    Its not possible to see from that pic,I will need to see it from another angle perhaps from below. Btw you have a mitsubishi td04 turbo fitted to that engine, I ca'tn tell if its an 11t or a 14t though, part numbers for that are printed on a flat spot on the side of the compressor housing you see un the pic.
    wales
    Thanks Nig, and thanks for the extra info, I wanted to know which turbo was on it too. is the turbo that's on it the one that people tend to swap out for a better one?
    Since you said you needed a picture from underneath, i had another look and there's a piece of steel there that says 'forge' on it that looks to be attached to the part you were talking about, so I guess that means it's been blanked!
  1. EGR blanked, but...
    By cammy3000 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2011, 23:05
  2. EGR blanked 2.0 DTI
    By superfox233 in forum Engine & Drivetrain
    Last Post: 17th February 2011, 15:31
  3. z20net recirc valve
    By jacko4 in forum Parts for sale
    Last Post: 15th February 2010, 12:27
  4. can the EGR be blanked on the DTI??
    By mick 1986 in forum Diesel Engine related
    Last Post: 17th January 2010, 20:10
  5. Air Con Recirc
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2009, 20:47
