Results 1 to 10 of 13
Thread: Signum 3.0 cdti, cutting out at speed
    Mar 2012
    Canterbury
    Vehicle : Signum Elite
    Engine : 3.0 V6
    Default Signum 3.0 cdti, cutting out at speed
    I have a 57 plate signum, 3.0cdti and when your going along say 70mph, it cuts out, so pull up, switch it off, then restart and it's ok again for a little while, days even!!! I have also noticed it sometimes does it when you accelerate hard from standstill, by the way it's a auto.
    Anyone got any ideas??
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Any lights active during problems?
    Am thinking MAP sensor or MAF sensor.
    If you have access to diagnostic live data will make it easier to diagnose.
    Mar 2012
    Canterbury
    Engine : 3.0 V6
    Yes the yellow spanner light and another yellow one between speedo and rev counter
    May 2011
    HEBBURN
    same problem on 1.9 cdti. MAF sensor was the problem.
    Mar 2012
    Canterbury
    Engine : 3.0 V6
    Will it show on a code reader? Also where's it located
    May 2011
    HEBBURN
    yes.cant remember code. but it will come up as air intake system leak. on the 1.9 its located in front of the air filter.
    Mar 2012
    Canterbury
    Engine : 3.0 V6
    Just put a code reader on and no codes or faults!
    Regular Member krazylegz's Avatar
    South Shields
    Could be the injectors
    But sometimes a faulty MAF won't show up a code
    Sent from my iPhone using my fingers n thumbs
    Quote Originally Posted by Wal2705 View Post
    The yellow spanner light, is this the one just beside the Fuel level warning light?
    The only other yellow one between the speedo and rev counter is the Traction Control / ABS
    Perhaps you could take a photo of the instrument cluster when this occurs, just to verify
    The symptoms sound like the early stages of EGR Valve failure, but it should return a fault code
    A faulty MAF is easily diagnosed, and will always return a fault code (as it is a standard VX part)
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Faulty mafs don't always put up a code I promise you.
    And they can also cause other fault codes
  1. cdti 1.9 cutting out any ideas?
    By matreya in forum Engine & Drivetrain
    Last Post: 18th February 2013, 11:19
  2. CDTI 150 Cutting out
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 23rd June 2011, 09:46
  3. cutting out after 15+ miles ??? 1.9 cdti
    By vtec mini man in forum Engine & Drivetrain
    Last Post: 9th June 2010, 12:19
  4. Signum Elite 3.0 V6 CDTi 6-Speed Manual
    By Maverick in forum Cars for sale
    Last Post: 7th January 2008, 14:09
  5. 3.0 CDTi limphome cutting in
    By kitchpoo in forum Engine & Drivetrain
    Last Post: 5th April 2006, 09:47
can a faulty maf on a vauxhall signum cause cutting out
