Thread: Lost drive and Grinding
    kent
    Default Lost drive and Grinding
    Hi i was out in my car today and all of a sudden i lost all drive and it was grinding when ever i put it in gear...
    Now im thinking it must either be a driveshaft or the differential...
    The only problem is i don't know how to check them to see what it is.. Im sure i could fix it myself just need to pinpoint the correct item...
    also it has not thrown the spanner but i did a scan anway and it does show up an error U2103-00 No Communication with CAN-Bus (Mid Speed ) now this fault may have been there already and i did not know as it did not show until i did a ECU scan with OP.COM
    The car is an 03 Signum 2.2dti auto
    and any advise on what i should look for first and how would be great...
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    mine did same last week, was inner driveshaft
    kent
    Thankyou so much i will take a look at mine
    kent
    Had a look at mine today and it turns out the circlip on the outer driveshaft broke and i have spent the best part of an hour cleaning bits of circlip from the front bearings..
    Just don't have the right sized circlip, i have most sizes but not the one i want when i need it...
    So tomorrow i will take my daughter to work and use her car and nip to vauxhall to get a circlip and a few spare circlips
  1. grinding into reverse
    By Daz d in forum Engine & Drivetrain
    Last Post: 21st October 2012, 16:09
  2. 04 sigbum 2.2 auto, lost drive
    By Mopar Man in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 11:06
  3. Grinding brakes
    By Chuddy in forum Handling & Braking
    Last Post: 1st August 2009, 14:02
  4. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
  5. HELP...Lost All Drive!!!
    By chrisschild in forum Engine & Drivetrain
    Last Post: 5th September 2006, 17:24
