Thread: Alarm Randomly going off???? - Vectra 2006 Estate
    Regular Member TheSnowMan's Avatar
    Jul 2011
    Bristol
    Vehicle : Vectra 2.2 Direct Estate
    Trim : SRI
    Engine : Z22YH
    Mileage : 123400
    Default Alarm Randomly going off???? - Vectra 2006 Estate
    Ive a Vectra C 2.2 direct 2006 Estate.
    Hoping someone can help, Parked the car up on the drive and locked up as usual, 10-15 mins later the alarm goes off. Reset and all ok another random time interval and goes off again. Keeps doing this..
    Put the op-com on and got :-
    B3901 - Wrong Environment Identifier Received
    (00) - Not present
    B3078 - Anti Theft Warning System Ultrasonic Sensor Circuit Malfunction
    (05) - Present
    Also Its the facelift 2006 Vectra Estate which I dont think has a backup battery for the Power Sounder?? Does anyone know if its got a built it battery???????????
    I've checked the Window Pane sensors which are ok, also op-com says Okay too, (I couldnt find anything on the rear window does anyone know if there is a window break sensor there? maybe it runs through the main demister element?? )
    Bonnet sensor is saying closed, and I've disabled the ultrasonics (By pressing the button on the dash before leaving).
    Still the alarm keeps going off (it could be 10 mins or 2 hours) at random intervals
    Its starting to get a bit of a pain not only with me, but the neighbours too! Starting to think its some kind of voltage fluctuation but dont know where to start 1st????
    Any help would be appreciated.
    Tony
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    It says it's the ultrasonic sensor do try disabling them with the button befor you arm the car and see if the alarm goes off
    VOTING UKIP IN AVELEY
    8 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    its seems a common fault with Estates and ppl having dogs ..their claws break the sensor elements .
    Regular Member John Bishop's Avatar
    Oct 2010
    I'd still put my money on the rear side windows. Unplug them and connect them using the paperclip method then see if it still happens. I have heard that the rear demister is also a part of the system.
    South east
    This fault only occurs on estates, and only estates have the sensors in the boot windows - it's got to be that.
    Jul 2011
    Bristol
    Trim : SRI
    Engine : Z22YH
    Mileage : 123400
    Disabled the ultrasonics, but still no joy
    Jul 2011
    Bristol
    Trim : SRI
    Engine : Z22YH
    Mileage : 123400
    Does anyone know where the sensor is for the rear window? and can it be "paper clipped?"
    Oct 2010
    Tony I would imagine you would have to take the interior trim off the tailgate and disconnect the heated element and paperclip them, at a guess
    PRESTON
    Just a shot in the dark, isn't the ultrasonic sensor fed by those dreaded ribbon cables that also power the interior lights? Maybe the one for the ultrasonic has a split or a short in it. Check they are connected firmly at the rear rec and at the sensor itself first, might just be a bad connection or has been knocked.
    I am sure that the siren does have a battery in it, but the battery is not replaceable and when this starts to pack up, it will cause false alarms.
    11 Post(s)
    Quote Originally Posted by barney490 View Post
    I am sure that the siren does have a battery in it, but the battery is not replaceable.
    It used to be, if you can still get the batts that is.
    But as already been mentioned, it's probably the break wires in the rear side windows of the car - no, not the rear windows in the doors, a bit further back than that.
  1. Alarm going off randomly
    By reesrk8 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th March 2013, 21:04
  2. vectra c estate 07 alarm sounder
    By sausaged in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2013, 16:52
  3. Alarm goes off randomly-have fault codes
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2012, 12:24
  4. Vectra C Estate Life (2008) Alarm Issues
    By Shoty32 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 14:38
  5. Alarm problem-06 vectra estate
    By graeme900 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th July 2010, 09:31
vectra c alarm keeps going off
location of the power sounder vauxhall vectra c estate
vectra c alarm ultrasonic sensorhow can i reset the alarm on my 2008 vectraalarm on vectra clock vectra alarm goes offvectra keep false alrminghow to disable a vectra car alarm systemvectra c power soundercar alarm keeps going off vauxhall vectra diesel estatecar alarm on vectra keeps going off randomlyAlarm keeps going off on my vectracar alarm keeps going off vectravectra c car alarm keeps going off vauxhall vectra 08 alarm keeps going off vauxhall vectra alarm going off randomlyhttps:www.vectra-c.comforumshowthread.php167082-Alarm-Randomly-going-off-Vectra-2006-Estateb3901 wrong identifier site:www.vectra-c.comvectra c alarm system site:www.vectra-c.comvectra c estate car alarm keeps going offhow to disable the alarm in vectra c estate
