Results 1 to 10 of 14
Thread: Wheel Advice plz
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    Default Wheel Advice plz
    Hi guys,
    Could do with some advice choosing the right size wheel.
    Currently 17" with 215x50x17 fitted. ( standard )
    Want to plan a budget for changing them this yr but want some advice on the best size. I don't want to buy a set of wheels then suffer a hard ride eg changing to a 20" set with rubber bands for tyres.
    Just wondering what you guys have fitted and what change it made to the ride.
    cheers
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    I recently went from 215/50/17 to 225/45/18 - great ride.
    Jan 2012
    Lancs
    Quote Originally Posted by Paulwr View Post
    I guess you haven't noticed the ride has gotten any harder then?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    225/45 18? or 225/40 18? If 225/45 so you have any issue with rubbing and are you aware the speedo is now out
    Sep 2010
    Quote Originally Posted by pthres View Post
    I gave my standard SRI with standard 17" wheels and tyres to our lass, now running an XP2 with the 18" 225/45 tyres,.. yes it is a harsher ride, but not bad in any way, steering is improved but would not fancy upping to 19"s
    Dec 2011
    Seaham
    You can google for a tyre rolling radius converter. This will allow you to compare your normal rolling radius and your new proposed one. The one I had seen also calculated the difference and advised your true speed against your recorded spped.
    Jan 2012
    Lancs
    Quote Originally Posted by s_zigmond View Post
    Yeah I'm aware it's going to change the speedo a lil bit, not too sure what you're trying to say about the rubbing?? I'm guessing don't go any wider than 225 or I'll suffer rubbing on the wheel arch?
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Sorry I meant do you getting any rubbing. I think I will go with 225 45 18 also when I finally find some alloys
    Jan 2012
    Lancs
    Link below gives a "visual" rep of the tyre size, but it also gives the actual dimensions. So a 215/50/17 sidewall is 10.75cm and a 225/45/18 sidewall is 10.13 cm, so the sidewall is only 0.62 down, wouldn't have thought would make the ride that much harder.
    http://www.kouki.co.uk/utilities/vis...ize-calculator
    Mar 2012
    Ormskirk, Lancs
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    The ride is a little firmer but that is a good thing it is not harsh or hard just a little firmer.
  1. VXR alloy wheel advice?
    By Del101 in forum Suspension, Wheels & Brakes
    Last Post: 15th December 2012, 14:38
  2. wheel advice 8.5 x 19 et 45 plz
    By timbo1980 in forum Styling
    Last Post: 11th February 2012, 23:04
  3. wheel advice
    By s31num in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2011, 14:59
  4. Wheel size advice
    By Bobarache in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2011, 09:33
  5. Wheel Advice
    By Badger59 in forum Styling
    Last Post: 10th October 2010, 12:26
