Thread: Bonnet Lever
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Bonnet Lever
    The lever has come out of its 'holder' and I cant seem to put it back in place..any idea's??
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    It pushes back in, but it's a bit fiddly.
    You need to remove the plastic trim around the lever there are 2 torx head screws. These need to be removed. the handle unit then clips back in.
    How do I know? Because I was doing this all day Sunday! (Cable slipped of the release spring!)
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Appreciate the heads up...at least your hassle Sunnday has helped someone else out..
    Feb 2012
    Calne UK
    No probs, like I say it's a bit fiddly, so be prepared to swear at it.
    Yeah I thought the handle module had come loose, thats why I had it all apart. In the end I needed to open the bonnet from under the engine! Anyhow I digress.
    The Handle is attached to a black plastic module thing, which clips into a metal bracket under the plastic trim. sadly it all has to be be removed to clip it back on.
    If you want to work on the module outside the car, you need to pull the handle to its maximum, then get a screwdriver on top of the cable and pull it down, forward and towards the centre console.
    It'll make sense when you have the trim off, but it's a sod of a position to work in!!
    Matt
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Whoa...best 5 minutes of my sad little life!!!..sorted
  1. bonnet release lever
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 21:25
  2. handbrake lever
    By kamil_p in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 21:14
  3. VXR Gear lever
    By Derek Mc in forum Styling
    Last Post: 2nd June 2010, 20:19
  4. Handbrake lever
    By lborob17 in forum Engine & Drivetrain
    Last Post: 7th November 2005, 11:53
