Thread: turbos
    dunfermline
    Default turbos
    i am wondering if this has been done ??
    i am led to believe that the 1.9 cdti 150 is the same engine as the tid 150 in the Saab
    and the engine in the Saab 93 ttid are the same but the manifolds are different to hold the twin turbo. has anyone tried fitting one of these ??
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    You are correct mate and yes we have tryed lmao not as easy as you think and needs a diffrent ecu to control the extra turbo with fuelling and air you will be better of with one big turbo
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Get a hybrid turbo conversion that will get the power you want
    dunfermline
    Okay was thinking that it would also need new exhaust an another oil feed an will be going down the hybrid at some point only just got the car lol
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    A hybrid turbo can happily produce 2bar of pressure from 1800rpm upto the red line, the only place you would see a benifit with the saab TT setup is very low in the Rev range. You could make up a sequential turbo setup with the first mechanically controlled by boost and the second via the standard method, You would need an oil line, a manifold and induction pipework. Bit more expensive than the £450 for a hybrid...
    Apr 2011
    Toulon, France
    I have managed 230bhp with a hybrid turbo on my 1.9 cdti150sri
    remember may need to upgrade brakes etc. I did.
    Blank EGR off and remap
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I have seen 215bhp at the road wheel so far on standard injectors and the road wheel power is a much better indicator of the vehicles output as the flywheel figure can not be accurately measured, only estimated or crudely measured on run down. Average losses over most of the rollers I have seen is about 36bhp lossed at 4000rpm, slightly more losses may be seen to peak power figures above this but the 50+bhp losses you get from places like Regal are not realistic and the lowest quote I have had is 21bhp which is also rather unlikely.
    Jun 2012
    Liverpool
    where can i get a hybrid turbo for my 1.9 150 and about how much am i looking just for the part, have remapped, pre cat de-cat , panel filter, scorpion cat back, but want more power , i know im not going to get much more without killing her but heard good thing about the hybrids , any sugestions ?
    Oh and does anybody know any dynos in the north west ?
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Most places only make 52mm comp hybrids which you would struggle to truely get over 220bhp but they can push out enough pressure low down to hit around 400lbft. if you are not changing anything else, that would be the way to go. AET, CR Turbos, Turbo Technics, a quick search will bring up loads. I have a Turbo Technics 52mm in the garage I am trying to shift that I ran over 200 road wheel power on.
  1. tampering with turbos??
    By bubba in forum Diesel Engine related
    Last Post: 25th January 2012, 18:40
  2. Damn not now! The turbos gone!
    By Innes in forum Engine & Drivetrain
    Last Post: 24th December 2011, 17:34
  3. 120 / 150 turbos
    By Nessy in forum Engine & Drivetrain
    Last Post: 12th January 2010, 15:23
  4. Turbos
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2006, 11:35
