Thread: Is there any truth?
    Nov 2010
    Maidstone
    Default Is there any truth?
    Since changing the wheels on the signum ive had this rather annoying wheel wobble between 60-70mph, spoke to an alloy specialist and he reckon at that speed its more likely to be rear wheel balance than fronts, is this true or a load of guff?
    Apr 2011
    essex
    Yep this is true. Over 60 mph wheel wobble most likely to be rears. If it was fronts you would already feel it at much slower speeds
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    I had a really bad vibration on my last car only between 55 and 65mph. Had the rear wheels rebalanced and the problem was cured
    Feb 2012
    North West
    Vehicle : 2.0 DTi
    Trim : LX
    Engine : Y20DTH
    Year : 2002
    If you changed to aftermarket alloys, did you use spigot rings?
    Nov 2010
    Maidstone
    These are genuine ronal vxr wheels, so should be a straight swop.
    May 2006
    scotland
    When you say wheel wobble, do you feel the steering wheel wobble? If so, I would say it was the front end. I had a wheel wobble only at 70 MPH ish (steering wheel wobble) and had my 2 front wheel balance checked. One was way out (had lost a weight). Once balanced, the wobble was gone. Therefore, front wheel problems can manifest at higher speeds only.
    Dec 2011
    Seaham
    Are the wheels true? Are the wheels balanced properly? Is there any deformities in the tyres?
    I am only asking as you said the wheel wobble has only started since swapping your wheels.
    Sep 2010
    When I had tyres changed I had steering wheel wobble after 60mph,.. turned out to be top shocker mount bearings. Was fine until tyres were changed
  1. Isnt it the truth
    By bobssignum in forum Comedy & Humour
    Last Post: 20th June 2012, 11:57
  2. HIDs and the MOT - The Truth
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2012, 23:36
  3. Who is telling the truth??
    By mikeq in forum Engine & Drivetrain
    Last Post: 16th July 2010, 13:42
  4. OK, Men. Tell the Truth. Do You or Don't you?
    By SignumPhil in forum General Chat
    Last Post: 29th October 2009, 21:32
  5. The truth about age
    By Vec-trance in forum Comedy & Humour
    Last Post: 8th May 2007, 09:48
