Results 1 to 2 of 2
Thread: 2.2 Direct EGR valve question
    Dec 2011
    Ayrshire
    Default 2.2 Direct EGR valve question
    quick question guys.
    Was cleaning out the egr valve on my 2.2 direct signum. I noticed when cleaning it out the flap which opens and closes is very stiff and hard to open. It closes itself and seals fine but is it meant to be so stiff? or Is it meant to move quite freely and with ease?
    Jan 2012
    Gloucestershire
    In the absence of anyone who knows anything about this EGR/engine replying so far, I'll have a guess! Most actuated valves require a fair amount (thumb pressure on 1.9cdti EGRs and throttle valves for example) of pressure to move, but move without gritty/lumpy movement. So, if you're having to wedge a screwdriver up the flap, that's probably not good, but if you're moving it with your hand, it's probably not bad!
    Sorry, really vague. Maybe someone else can help more.
  1. 2.2 direct.how do i remove and clean egr valve?
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd February 2013, 21:58
  2. Egr valve.can i clean & refit on a 2.2. Direct.
    Last Post: 16th September 2012, 23:28
  3. Egr valve on 2.2 direct.anybody advise on replacing one?
    Last Post: 13th September 2012, 20:45
  4. Help me find egr valve on 2.2 direct.
    Last Post: 13th September 2012, 17:20
  5. EGR valve question - 2.2 Direct
    By Boy Lard in forum Engine & Drivetrain
    Last Post: 15th June 2012, 20:39
