Results 1 to 10 of 11
Thread: EGR VALVE error P0400
    Jun 2012
    essex
    Default EGR VALVE error P0400
    hiya everyone my signum keeps dieing on me just completely shuts down and pluged it in and got a MAF error and EGR valve have cleaned bout of them and still the EGR valve error keeps coming up any idea cheers
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is the egr valve moving freely?
    Had this fault in a 1.9 Zafira today an the spring in egr was jammed closed with all the crud
    Jun 2012
    essex
    To a point it is moving freely doesnt seem to close compelely tho and i cleaned it as best as i could just wouldnt close shut
    Northampton
    Engine : A20DTH
    Mileage : 88000
    well considering it will not close indicates it needs replacing
    Jun 2012
    essex
    i understand that but there doesnt seem like a not pressure on the spring to return it to close anyway normaly do thy slam closes with out any gaps at all due to mine has a mm or 2 in it cheers
    Northampton
    Engine : A20DTH
    Mileage : 88000
    they seal shut until you hit a certain engine speed when it opens. Car will not run correctly at low speeds if the valve does not close fully
    Jun 2012
    essex
    thank you for your reply and oh right ok so that could be what would be making my car smoke aswell then and have just been told i would be able to by pass it and if so would there be any further problems by doing so thank you
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes you can bypass it by unplugging it but it will show up a fault light. Problem is tho yours is not shutting correctly so unplugging it will not help. You can get it mapped out but you will still have the same problem until you can get it to close or put a blanking plate in
    Jun 2012
    essex
    if i put a blanking plate in can it cause any damage its self cheers
    Northampton
    Engine : A20DTH
    Mileage : 88000
    No but you will have a warning light
    http://www.ebay.co.uk/sch/i.html?_nk...at=0&_from=R40
  1. Fault p0400 (57) (EGR Valve Voltage Low) on Z22YH
    By VeCeZ22YH in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2012, 20:25
  2. P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:19
  3. Error code p0400, EGR help.
    By Rainbow6six in forum Engine & Drivetrain
    Last Post: 21st July 2010, 10:07
  4. got DOOR DISABLING SOLENOID VALVE ACTIVATION ERROR any ideas???
    By axe_sri in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2009, 23:06
  5. Error code: P0400 - EGR
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 3rd January 2008, 17:20
vectra 2000 error 0400
