Results 1 to 3 of 3
Thread: Please help with the following codes on my signum
    kent
    Default Please help with the following codes on my signum
    My 03 Signum 2.2 dti has thrown the dreaded spanner..
    I have OP-COM and the fault code's read
    P1105-FA Barometric Pressure not Plausible with Boost pressure
    and
    P0105-FA Barometric Pressure not Plausible with Boost pressure
    when i clear the codes they come straight back please help with what the codes mean so i can fix it...
    Paul
    South east
    At a guess, I'd say your MAP sensor needs to be replaced, or perhaps it can be cleaned. Alternatively, there could be a boost leak somewhere and the MAP sensor is reporting the missing boost as the discrepancy.
    kent
    Many thanks i manage to fix this today... I cleaned out the EGR and that seemed to have done to trick but on a test drive another problem occured and i lost all drive to my car and a grinding noise when its in gear...
    This car has had so many things go wrong with it in the 4 years i have had it....
  1. Signum CD70 Sat Nav - Post Codes
    By alhambra in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2012, 10:31
  2. ERROR CODES signum 2.0 diesel
    By signum_05 in forum Engine & Drivetrain
    Last Post: 27th June 2012, 07:52
  3. 2006 Signum 2.2 engine fault codes! Help please :)
    By t13con in forum Engine & Drivetrain
    Last Post: 16th January 2011, 16:39
  4. Signum 2.0 dti fault codes
    By Babycake in forum Engine & Drivetrain
    Last Post: 7th April 2010, 11:25
  5. Sick Signum 2.2 Direct (Fault Codes)
    By kaston in forum Engine & Drivetrain
    Last Post: 13th September 2007, 10:31
