Thread: Oil Catch Can Fitted
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    Default Oil Catch Can Fitted
    New catch can fitted, new manifold later in year, hopefully this and my egr blank will keep it clean.
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    That looks smart mate, where did you mount it.
    Does it have to be lower than the cam breather outlet?
    Doing mine at the weekend..
    Matt
    Jan 2012
    Lancs
    Quote Originally Posted by VVT-i-MATT View Post
    Matt
    If you look at the top 2 pics you can just see the bracket / plate I made, I mounted it onto that, and mounted the plate onto the mounting bar of the unit to the left, I could possibly mount it slightly lower however it's already working where it is. I can see there is oil on the left hand pipe ( from the engine breather ) but non in the right hand pipe, return, so therefore I can see it's working. I've also put 2 stainless steel scouring pads inside for the oil and deposits to catch onto, this will let the clean vapour breath out.
    Most people are mounting theres to the bulkhead on the right hand side of the water expansion bottle, I mounted mine where it is because the pipes are shorter and I can mount it lower.
    Feb 2012
    Calne UK
    Now you point it out, I can see the bracket.
    Looks good, nice one.
    Matt
  1. Budget Catch Can Fitted
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 3rd February 2013, 19:28
  2. Who has an oil catch tank fitted?
    By lee gsi in forum Diesel Engine related
    Last Post: 22nd January 2012, 13:24
  3. Fitted a Oil Catch Tank for DTI
    By Innes in forum Diesel Engine related
    Last Post: 9th October 2011, 14:18
  4. Just Fitted Oil Catch Tank (couple of pics)
    By john506 in forum Diesel Engine related
    Last Post: 7th September 2011, 10:17
  5. Replies: 14
    Last Post: 3rd September 2011, 20:23
vectra c 1.9 oil catch can
will a catch can work on vectra c 1.9
Vauxhall 1.9 cdti oil catch can
