Thread: Vectra C Estate 1.9 CDTi [150] - Creaking from rear...
    North East
    Default Vectra C Estate 1.9 CDTi [150] - Creaking from rear...
    My car has been what can only be described as 'creaking' from the back end for some time now. It was in for a service last week (non vx dealer) and I was told this is a common problem with vectras and that its the rubber on the bushes. The mechanic didn't think the bushes needed replacing so he greased the rubbers. The car really creaked a lot when I first left the garage but is not as bad now but it still creaks a lot just the same as before it went in for a service.
    Is this a common problem and should I persue getting it sorted or will it be fine? I am a bit paranoid as I am going to be towing a caravan in a couple of weeks for the 1st time and don't want any unecessary problems..
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Hi, i've had an occasional creaking noise from my estate's back end since i bought it nearly 3 years ago. It got worse last month so i jacked the back end up and found the bottom coil of each spring had broke. The broken pieces were just sitting inside the rest of the spring, but if they had fallen out it would have been very hard to see that they had broken. I fitted a set of Eibachs and the noise went.
    South east
    MPC - the mechanic is right in one respect, it could well be caused by one or more bushes, but if so it's because they're worn and need replacing. Check the springs first, then have a good look at any bushes you can see, look for any splits or cracks in the rubber.
    North East
    I am pretty sure the rear springs are ok and will have been checked out by the garage as they have changed the front springs for me before. I'm confident they would have said if there was anything not quite correct with them.
    I have the car booked back in on friday for them to have another look. If they offer the solution as being changing the bushes what sort of cost should I be looking to pay to get this done?
    South east
    It depends on which bush it is, as some take less time that others to replace, but at a guess I'd say no more than 1 hour's labour charge.
    North East
    Thanks for your replies guys, I have found that if its wet outside the creaking isn't as bad!! Is this normal/typical or am I just going mad! I have come in to work this morning and its wet and I couldn't hear any creak at all yet last night it was noisy as ever?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Yep water lubricates the suspension parts and the creaking lessens.
    I have had creaks from the suspension of my estate since I got it (had it over six years!).
    Every time it goes in for a service I mention it and they just say it's the bushes, but no need to replace them as they haven't cracked and there is no play in them.
    I have had a rear spring go once but I never noticed that!!!!!
  1. Vectra 3.0V6 CDTI XP estate
    By Markv6ST in forum Vehicle Diaries
    Last Post: 29th July 2016, 17:17
  2. Vectra C 1.9 cdti estate
    By winton40 in forum Troubleshooting
    Last Post: 25th May 2011, 16:36
  3. cdti estate rear twin exits
    By winnie2457 in forum Diesel Engine related
    Last Post: 5th July 2010, 00:14
  4. creaking front when braking 1.9 cdti vectra 2006
    By tony whin in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2009, 17:18
  5. rear exhausts 30 cdti sri estate
    By 30ltr nutter in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 21:46
