Thread: alternater fault
    Jun 2012
    york
    Default alternater fault
    hi all sunday my red alternater light came on put my meter on the battery just over 12 v started the car it droped to 11.5 and and didnt go up even when i increased engine speed i allso noticed the yellow car/spanner light was on when i first turned the key changed the alternater yesterday put my meter back on with the engine on tick over got 13.8 went for a run all ok but the yellow car/spanner light still comes on when i first turn the key and goes off when it starts it runs fine i have drained the fuel filter still the same would it be best to change the filter to see if that sorts it
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    The fault is still stored in the ECU, it should go off after a few starts... You could just clear the stored faults by disconnecting the battery for a few minutes, that should do it.
    EDIT - See this post -
    http://www.vectra-c.com/forum/showth...=1#post1802615
    11 Post(s)
    Welcome to the Vec-C forum.
    Don't want to state the obvious, but this part of the forum is called "introduce yourself".
    You need to ask your question in aonther part of the forum, where among other things, you'll have a bigger audience reading your post and may be able to help you.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to electrical The introduce section is for posting a bit about yourself
    Irmscher Insignia CDTI 130
    Quote Originally Posted by mash View Post
    That is the Emissions Warning light
    It is supposed to come on during engine start up sequence
    It is only an issue when it stays on when the engine is running
  1. possible alternater failing?
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 18:32
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. smoking alternater
    By jofenan in forum Engine & Drivetrain
    Last Post: 28th January 2011, 08:47
  4. DAB fault??
    By Desulph in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2008, 18:59
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
