Thread: Washer Fluid Indicator
    Nottingham
    Default Washer Fluid Indicator
    Keep getting washer fluid check coming up on display despite there being plenty in there - any suggestions as to how to stop it?
    11 Post(s)
    Most probably the float in the bottle is stuck, failed, or the wires to it have become detached.
    Regular Member coldo's Avatar
    Scotland
    +1
    Check the connector first of all to make sure it is not loose or has become detached. If it is connected take it off and spray the conectors with contact cleaner. Once refitted if that makes no difference then get a new float and swap it out. A new float is a few quid from Vauxhall. If that does not work then there is another underlieing issue.
    If all else fails just cut the wires at the plug and connecto them together to complete the circuit. That will put the warning off permanently but will mean you will not be warned.
    Nottingham
    Thanks Guys - I'll give that a try
  1. low washer fluid warning.
    By frasedeb in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2012, 22:11
  2. Washer fluid leaking
    By monty2000 in forum Bodywork & Interior
    Last Post: 3rd February 2012, 11:47
  3. Windscreen washer fluid
    By Sigmacca in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2011, 20:14
  4. Washer fluid check.
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 14:07
  5. Which washer fluid?
    By vxvirgin in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 08:15
