Thread: Scotch locks
    Jul 2011
    UK
    Year : 06
    Should u use them am going to do some wiring connecting into the cig lighter and thought scotch lock would be easier
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Scotchlock are an easy option, but you would be better having soldered joints
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by phil67
    That's what I was thinking but for short wires and hard to get to
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    I have used scotchlocks before on several things (low power resources) and most of the time they are ok, whats the worst that can happen, it stops working and then you can always solder then
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    I have used them in all my wiring not had any problems, as long as when closing it dont use the clip lid to close it use a pair of pliers to compress the metal contact into place (flush with top section) then close lid by hand. The reason im saying is that some people use the lid to lock and clip into place, and sometimes depends how strong the wire sleithing is sometimes pushes the metal conector through the lid not making a conection .
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Scotch locks will take 50v max so 12 is fine alot use then for connectin tow bars up
    Regular Member Ann's Avatar
    Jul 2011
    Northamptonshire & Derbyshire
    scotch locks are good, probably better than solder, as sometimes solder can corrode (probably only after a billion years though)
    Jul 2011
    UK
    Year : 06
    Thanks for the advise great as always I've orderd 20 of them for 1.49 i think it was then 90p postage on eBay am going to be wiring up sidelights to the cig lighter so they come on when I unlock the car and I can put leds in then place the normal sidelights somewhere where they are not seen
  1. Joint Meet with Yorkshire Region Scotch Corner 15th July 2012
    By Mark Evison in forum North East RO Vacant - ARO - Vacant
    Last Post: 15th July 2012, 10:37
  2. Scotch bloc connector failed - Rev. Sensors
    By Dal5band in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 22:49
  3. Scotch with two drops of water
    By Derek Mc in forum Comedy & Humour
    Last Post: 12th December 2010, 10:50
  4. Scotch Corner 1pm 10 Feb 08
    By ViperSRi in forum North East RO Vacant - ARO - Vacant
    Last Post: 9th February 2008, 18:25
  5. scotch tape advert
    By benny in forum General Chat
    Last Post: 8th November 2006, 21:46
