Thread: white smoke help
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    Default white smoke help
    right my 1.9cdti 150 siggy has just started to puff white smoke every now and then. i dont think the turbo is leaking as i havnt lost any oil and its not constant. im thinking it might be a sticky egr valve. what do you lot reckon?
    Apr 2012
    littleport
    anyone? should i clean the egr up and see what happens?
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Maybe a slightly lazy injector.
    Cleaning the egr won't do any harm an since it's easy to get to prov worth doing just to rule it out
    Jan 2012
    Gloucestershire
    If you're sure it's white smoke, that's an indication of water burning off. Check your water reservoir level - if ok, maybe just condensation within your exhaust?
    Dec 2011
    Seaham
    Could also be brake fluid? Check your brake fluid level, it is not unknown for brake master cylinders to weep through the seals, into the vaccuum unit and then into the engine.
    Apr 2012
    littleport
    water, brake, and oil are all fine
    Jan 2012
    Gloucestershire
    If you're not losing any engine fluids then I wouldn't worry about it, but would keep a close eye on those levels in case its early signs of something going wrong.
    EGR is generally worth cleaning out periodically; I do mine whilst waiting for the oil to drain during basic service.
  1. White smoke
    By Mark fisher in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2012, 10:42
  2. Replies: 18
    Last Post: 20th November 2012, 21:41
  3. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  4. White smoke!
    By stickygreen in forum Engine & Drivetrain
    Last Post: 1st February 2012, 19:02
  5. White Smoke???
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 4th February 2011, 17:37
