Results 1 to 10 of 13
Thread: Transmission Issue??
    Apr 2012
    Sussex
    Default Transmission Issue??
    Sooooo...I have a 2003 Vectra C 2.2 CDTI with an Auto gearbox. It has just over 100k on the clock and I am having a problem.
    Intermittently it locks me into 5th gear and a image of a car with a spanner sticking out of it comes up on the dash display. If I move into tiptronic control, I can only switch between 5th and 2nd with no gears in between.
    Spoke to a mechanic and he said the error code is showing up as something to do with the transmission and he mentioned something about a seal going that is allowing water into the gearbox which 'is apparently setting off the alarm' or something.
    Spoke to Sussex Automatic Transmissions and was told that its a common problem on Astras but they do see it on Vectras and they quoted me 2295 squid to fix. *AAAAAAAAAAAAARRRRRRRRRRHHHHHHHHHGGGGGGGG*
    Someone tell me that they have had a problem like this before and it was a common and cheap fix. The car is only worth 1750 - if that.
    Anyone? Anything? Please......
    Jun 2012
    tamworth, staffs
    It could be coolant going into box from a failed seal between oil cooler and radiator. But that normally destroys all gears.
    You can get it repaired a lot cheaper than that. Was quoted £1800 for a fully recon box for my 2.2 dti.
    Clutchmasters in Coventry quoted £1200 to remove recon and refit box.
    Jun 2012
    tamworth, staffs
    Have you any idea what the error code was that car brought up?
    Apr 2012
    Sussex
    dont know specifically what the error code is...no. Sorry. 1800 quid is still alot of money for a car that isnt worth that....what to do?!? *tears*
    Jun 2012
    tamworth, staffs
    Have you looked at any breakers or salvage yards?
    Apr 2012
    Sussex
    I havent considered breakers to be honest. Been thinking more about it and I think its probably easier for me to sell the car and maybe a mechanic will be lucky enough to snap it up and he can sort the work himself. Its much too much issue and cost for me and I really dont think I have the time for it. Shame. Really enjoyed the vectra while it was all up together.
    Jun 2012
    tamworth, staffs
    Before giving up on it, you need to find out what gearbox is fitted to it. Either give reg no and chassis no to vx and they can tell you or if you look down between engine and battery box there is a plate on top of box telling you, eg AF33, AF17, AF50 etc. It does take some finding but its there. It may even be in your service book.
    Once you have the number, we will go from there.
    Apr 2012
    Sussex
    Well, according to the gentleman at Vauxhall its an AF33. Couldnt manage to find it anywhere under the hood.
    South east
    You firstly need to find out exactly what the fault codes are, then a definite diagnosis as to the cause, before you go to the drastic step of selling the car at a knockdown price.
    Apr 2012
    Sussex
    Where can I find that out somewhere that's not going to charge 100 quid just to connect a computer to it?
  1. sounds like Transmission knock
    By pipamish in forum Engine & Drivetrain
    Last Post: 24th August 2012, 20:25
  2. Transmission losses
    By Hideous in forum Diesel Engine related
    Last Post: 16th April 2011, 10:48
  3. Gear box transmission oil?
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 17:37
  4. Transmission Snatch
    By JDL in forum Engine & Drivetrain
    Last Post: 16th December 2010, 16:02
  5. transmission problem
    By clarkey in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2007, 20:48
