Thread: Vectra 3.2 V6 intermittent running fault
    Jun 2012
    birmingham
    Default Vectra 3.2 V6 intermittent running fault
    The problem I am having with my vectra is it seems to have an intermittent running fault,it still starts and drives,and doesnt misfire,however after a few miles it seems to hesitate and the engine management light flashes intermittently,and so does the battery light, then its ok for a bit and then it does it again..the rev counter jumps up and down etc.
    Please help.
    My first instinct is the alternator
    What mileage is the car on?
    Jun 2012
    birmingham
    Its on 117,000
    Quote Originally Posted by riddy View Post
    Its on 117,000
    Seems a fair mileage if it is the original alternator
    Have the voltages checked
    Jun 2012
    birmingham
    BUt if it was the alternator wouldnt I have problems trying to start the car as the battery would be drained?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    As you said its an intermittent fault... Its obviously charging the battery to a point, but after driving for a while its putting a drain on the battery as its not charging it as it should. As m8internet says, get the voltages read... Sounds like the Alternator or battery is going to die soon.
    Should be just above 12 v across the battery and just under 15 v (14 point something I think) when running... measure that, then turn things like the AC, lights, radio etc on and see if there's a drop in the charging
    That would only happen when the alternator has finally died, it can take some time for this to happen
    The other time this would happen is if the belt powering the alternator has worn, out of tension or slipped
    As a petrol it should still start, but the alternator light will remain on throughout
  1. 1.9 CDTI 150 Intermittent Stalling When Running
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 11th August 2012, 22:03
  2. Vibration and intermittent ABS Fault?
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:49
  3. CDTi 150 intermittent running problems
    By JonSRi150 in forum Engine & Drivetrain
    Last Post: 20th December 2010, 14:13
  4. dash intermittent fault
    By winnie2457 in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2010, 01:04
  5. Vectra C intermittent fault
    By Majorlook in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2007, 13:41
intermittent starting problems with vectra c 3.2 v6
