Results 1 to 10 of 11
Thread: Outside LEDlights in the bottom of mirrors
    Mar 2012
    Norway
    Default Outside LEDlights in the bottom of mirrors
    I'm thinking about mounting some LEDs in the bottom of the outside mirrors to light up when coming to/from the car.
    I have seen that the license plate lights up as soon as I unlock the car, and I think also when stopping the engine. In both cases the light stays on for about 5 minutes or until the car is locked.
    Is it some place in the front of the car I can pick up this wire, or does it come from the REC?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Interior light is best bet...
    Jul 2011
    UK
    Year : 06
    I was thinking about somthing similar and take a wire from the rear number plate to a side light connection with the normal side lights piggy backin
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by marc vectra sri View Post
    So you can run LED side lights? that come on with the key fob?
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by leemarksmith
    Correct mate and they still work as side lights
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Like this
    Wired to the dash light loom, even easier
    Jul 2011
    UK
    Year : 06
    Like this
    Video Link: http://youtu.be/UpwowctU7_s
    Explain lol and how u get fogs to come on I no my next mod now
    Wiring to the dash loom it won't come on as u turn side lights on will it
    Mar 2012
    Norway
    Quote Originally Posted by leemarksmith View Post
    I didn't check the interior light, but does that work on the same way?
    Do you know how long they stay on?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Quote Originally Posted by Thomza View Post
    Until you put the key in or 30 seconds or so?, then that way there only on when your interior light on, which if you dont really use it is just with the fob or getting in and out...
    There's a thread flying about on how i did it, but i cant find it... But basically i got some 501 bulb holder that would fit the lights, then just used a bit of speaker wire from the Yellow/Grey dash light feed, like the cig lighter light etc... Run the speaker wire to the front of the car and slot it. Drilled the fogs from the top to slide a set in too and job done... these now work when the dash does, so fob lock, unlock and with light switch...
    You have to leave the old 501 lights connected and with bulb in but i just wrapped in tin foil and leave loose in the light cap. no issue and been like this ages...
    Jul 2011
    UK
    Year : 06
    Thanks mate will go to the scrappy on tues
  1. Front bottom arm
    By Jonsey in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 19:20
  2. Spring help top or bottom
    By vekky c in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2012, 11:45
  3. Something is hanging off the bottom of my car
    By benwalters82 in forum Bodywork & Interior
    Last Post: 2nd September 2010, 10:59
  4. Top , Middle or Bottom
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2007, 18:10
