Thread: Electric circuits testing problem
    Nov 2009
    Warwickshire
    Default Electric circuits testing problem
    My battery has been running down when switched off overnight. The battery, alternator and starter have been tested and eliminated as the cause.
    I've done a parasitic current draw test on the battery and it shows a draw of 65 milliamps. I understand the correct figure should be in the range of 25mA to 35mA. Pulling fuses from the engine fusebox shows the suspect draw coming from the passenger fusebox. The problem is the front passenger door has to be open to give access to the passenger fusebox. But opening any door switches on various circuits and prevents getting an accurate reading of current draw. I've tried jamming the door latch without any success. Has anyone found the way to isolate the door lock sensor? Thanks.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Can you not remove the glove box an built fuse box an try it that way?
    Or am not sure how the lock sensor works but maybe use a paper clip or similar in the lock connector to trick it into thinking door is locked.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    How are you testing it...? Amp meter fitted car locked walk away for ten min for all systems close down then see what draw you have ...? Most common draw I've found on these is a faulty uec Giveing a small drop riseing to a large one over time then dropping back down again .....
    Nov 2009
    Warwickshire
    Quote Originally Posted by Critch View Post
    Unfortunately the fuse box is built into the end of the facia. The paperclip is a good idea I'll give it a try. Thanks.
    Nov 2009
    Warwickshire
    Quote Originally Posted by benny View Post
    Yes - testing as you say. Initially the draw is about 2amps then after about 20 mins it drops to 65milliamps. I've taken the reading at various times over 24 hours and it is always constant 65mA. But pulling F31 in the engine fuse box drops the draw to15mA. Thanks for info - can I just ask what is uec. cheers
  1. Electric problem !!!
    By m.service in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2011, 13:42
  2. odd vec c problem, electric window
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2011, 00:34
  3. Electric Window Problem
    By TrevF in forum Bodywork & Interior
    Last Post: 19th October 2008, 15:15
  4. Electric mirror problem.....
    By sonic in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 00:36
  5. electric window problem
    By jon ixi in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 23:23
