Results 1 to 10 of 15
Thread: Z19DT Exhaust Temp Sensor Help... & Thermostat...
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Default Z19DT Exhaust Temp Sensor Help... & Thermostat...
    If this wasnt working properly, what would it cause?? As i belive mine is reading -40degrees i think... Which to me... i know isnt true...
    Also how easy is the thermostat to change, as it never really moves of the bottom when driving, only when in traffic.
    Cheers.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Hello??
    Nov 2010
    East Midlands
    Trim : design
    Hi, Do you mean the coolant temp sensor when you say exhaust temp? The thermostat on the 120 is a bit of a pig to replace on this engine - there are loads of previous posts on the Forum if you do a search.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    No mate, ive replaced the coolent temp sensor already when i was having starting problems, which turnt out to be the starter motor lol.
    They have a exhaust temp sensor on them.
    If you are seeing -40 on the display in the centre of the dash its the external temp you are seeing, the sensor for it is mounted behind the number plate area of the front bumper. It will need to be replaced and its not expensive.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Nooooo its not the outside temp sensor lol
    I put tech 2 on it, and its showing exhaust temp sensor -40 degrees, now autodata shows this to be at the front of the engine bay?? on the exhaust?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Vectra Adz View Post
    Cheers.
    It fits into the particulate filter.
    Part number
    55557466
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Mine dont have a particulate filter? lol
    Dear o dear... whats going on here then lol
    Either way, its saying mines -40 lol
    May 2011
    South London
    The following models are currently fitted with a DPF.
    1.3 Diesel Meriva
    Combo from MY 07
    1.7 Diesel All Corsa D
    1.9 Diesel All Signum
    Vectra Estate
    Vectra Hatchback with automatic transmission
    All Zafira B
    Astra H with automatic transmission only
    All Astra H Twin Top
    All 2007 Spec Astra CDTI's including Manuals
    3.0 Diesel All Vectra and Signum as of MY 06.5
    2.5 Diesel
    (146PS ) Vivaro from MY 07
    Movano from MY 07 (146PS version only
    You only stated Z19DT The assumption is you have an Estate or a Auto.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    oh right, mine is manual 6 speed on 04.
  1. Thermostat or temp sensor
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2013, 08:07
  2. Is it the temp sensor or thermostat 1.9cdti
    By bennettboy in forum Engine & Drivetrain
    Last Post: 28th October 2012, 12:45
  3. thermostat & temp sensor
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 16th December 2011, 12:37
  4. cant unplug my temp sensor on my thermostat
    By justin32 in forum Engine & Drivetrain
    Last Post: 10th December 2011, 16:16
z19dt thermostat change
vectra c exhaust temperature sensor
z19dt thermostat
club opel vectra c 1.9 cdti sensor thermostat
z19dt coolant temperature
