Results 1 to 10 of 11
Thread: clutch issue question
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    Default clutch issue question
    been out in the car today and when setting of in first slowley and letting the clutch out the was a slight noise/feed back in the clutch pedal, the gears are fine to change no slipping of the clutch and th ecar drives fine does the clutch need to be changed or is it the dmf eek nothing in 2nd 3rd 4th 5th or 6th, onlu in first and reverse
    any advice guys would be great
    forgot to mention its a 1.9cdti 120 56 plate with 64k on clock
    cheers Craig
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 136000
    whats the cars mileage on?
    Apr 2006
    64k on clock Ste
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    is it rattleing then ? or have a vibration
    Apr 2006
    more off a vibration no rattle at all, the gears change fine not stiff or hard not slack nice and smooth strange, it dosent do it all the time i forgot to mention. wife noticed it the other day but forgot to tell me
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    as long as you can select gears your ok
    have a read of this
    http://www.vectra-c.com/forum/showth...wirl-Bar/page7
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Get the DMF, clutch kit, and slave cylinder done all at the same time. can be supplied and fitted for around the £800 mark.
    Don't go to a main dealer, you'll pay more than double that
    Apr 2006
    thanks for that ste ill do a bit of shopping around would it best to do is a soon as possible or will it be ok to drive till i have chance to sort it out would you say its the dmf or just the clutch ??
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 136000
    Quote Originally Posted by murf2484 View Post
    people still drive with the vibration and rattling ive seen on here but normally people have trouble getting a gear eventually
  1. Clutch issue
    By shepe in forum Engine & Drivetrain
    Last Post: 7th October 2012, 19:50
  2. Issue with clutch pedal - any advise please?
    By graded-appliances in forum Insignia car chat
    Last Post: 9th October 2011, 14:12
  3. Vectra C 1.8 Clutch/Gearbox issue?
    By ukmgdrooling in forum Engine & Drivetrain
    Last Post: 13th May 2011, 22:57
  4. 1.9CDTI 150 clutch / flywheel issue
    By LGD in forum Engine & Drivetrain
    Last Post: 28th January 2011, 00:29
  5. clutch pedal return issue
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 17:01
