Thread: Left indicator flashing fast, front indicator not working
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Default Left indicator flashing fast, front indicator not working
    Hi guys..
    It just started on my Vectra 2006 facelift...
    When turning left, indicators flashing fast.
    *Bulb checked, no sign of the bulb not working, but changed anyway.. Still not working...
    *Gave the headlight plug electricspray.. still not working.
    *When hazard light is turned on.. the flash is back to normal, but left front indicator is not flashing at all.
    *Fuses checked.. still not working.
    *Trailer module changed (because there were no light on the trailer at all...) still not working.
    Sometimes on start up the front indicator flashes normal for 3-4 times, then start flashing fast again.
    Please help!!!!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    14 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    may be worth a try roughing up the connector with sandpaper/wet n dry to remove any rubbish,you could also try adjusting the tightness of the bulb holder..
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by nikroc View Post
    The connetors are as new and there is no rubbish in them... I could try the tightness of the bulb holder... But I can remember that it already was a tight fit...
    But thanks for the hints..
    Mar 2012
    Norway
    Have you measured the voltage in the bulb holder? Try with hazards on.
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    No haven´t tried to measure voltages... My hands do not work for me to be doing that... With hazards on it won´t flash either..
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    I have solved my problem..
    Toke it apart again today and found that one of the terminals in the headlight housing had burned a hole in it.
    So I just cleaned it up a bit and didn´t screw the bulbholder completely in.. It is still tight and there is connexion to the bulb now.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by kenp View Post
    Yes finally got it sorted...
    But soon it will take a new headlight to fix it... Then AFL it must be...
  1. Rear Indicator lights are white when flashing
    By akeem in forum Bodywork & Interior
    Last Post: 15th February 2013, 20:46
  2. left indicator flashing fast
    By bigpaul08 in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2012, 11:22
  3. boot and rear left indicator not working
    By lander7394 in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 20:12
  4. Left indicator and right main beam not working(help)
    By kalim in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2009, 14:10
  5. Flashing AFL indicator
    By IanW in forum Vectra C / Signum Troubleshooting
    Last Post: 13th December 2008, 20:04
vectra c indicator problems
indicators flashing fast vectra c
vauxhall vectra front indicator not working why
2007 vauxhall astra indicator not working
vectra c front indicator bulb holder fault
front indicator not working on a vauxhall vectra
vectra 2007 headlight not working
rear right indicator not working vectra c
indicator fault on vauxhall Vectra
vauxhall vectra 2008 left indicator faulty
2007 zafira front indicator not working
vectra c rear indicator not working
astra front indicator not working
One front indicator not working
