I think it is about £15 www.seriousperformance.co.uk
Brocks: - you can use the detail spray that came with the megs clay for spit polishing, you can even use chilled water, mind you whatever you use it's best when chilled
And Ed: - OCW, good choice it will sit over 476s great and will get better and better with every application, remember you can use it on your wheels (to bring out the fleck/bling) and OCW will not affect plastic/rubber infact it can be used on both
Bryan
Define Chilled....Out the Fridge? or left outside over night at this time of year?
Cheers guys.....Role on the Chrimbo Holiday.
Hey Brocks remember though when you're spraying your detail spray make sure it's a VERY FINE mist........you don't want big globules just a very fine mist
Bryan
I may clay the car too.....But i'm out of clay...Doesit have to be megs or are they all the same?
Most are much the same the Brocks but I like using Sonus Green or the "Poly Clay" like Mothers ..........if it mentions aggressive forget it you want a mild one
Bryan
Certainly will be. Cleaned the car today as it was absolutely minging after my drive up yesterday...........
but seeing as it decided to be fappin' freezing and frosty in the NE today all I did was give it a wash and dry. Hopefully tomorrow will be a bit milder and I can get the polish, sealer and wax on! Got the 476s sat in the airing cupboard to soften it up nicely to ease application.
Is it worth doing the spit and shine? (best thing I've probably got with me is the Megs Speed Detailer) or should I just concentrate on getting a layer on the car first?
