Results 1 to 10 of 26
Thread: Spit Shine.....What exactly is it?
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default Spit Shine.....What exactly is it?
    As above really....Seen it mentioned on a few forums. All talk slightly differently so I kinda lost the plot. Like the results though!
    Maidenhead
    Quote Originally Posted by Brocks View Post
    Spit shining is a method used to apply two layers of wax simultaneously, which wouldn't usually be possible, a wax has solvents in it to make it "soft" and easy to apply to the paintwork, and these solvents remove some of the previous layers of wax applied. If the previous layer of wax was just applied, the solvents would remove all of it so just doing one layer of wax after the other would have no benefit which is why you are advised if planning on layering waxes to leave 24hrs between coats...
    Spit shining aims to neutralise the solvents in the second layer of wax allowing a second layer to be put over the first right away without having to wait 24hrs. To so this, apply first layer to a panel and allow to haze. Mist the panel (without removing the residue or haze of the first layer) with a chilled quick detailer spray. Apply the second coat straight over the misted quick detailer (before it dries) and work gently until you get the normal wax haze. The remove the residue.
    Hope this helps!
    Some people put a coat of wax on a car (don't rub off though) and than apply spray wax and then another coat of wax etc etc etc.
    Similar to the way we used to polish our boots in the armed forces.
    Feb 2006
    Wirral
    I assume I can use the detailer spray that came with my meguirers Clay bar....
    I want to give the car a really good going over during the hols....Might try this if time and light allows!
    I may be trying the Callinite stuff too?
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    is it the same as spit roasting mate lol?
    What a nice constructive answer. Well done.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Quote Originally Posted by AJA View Post
    why thank you one does what one can!
    Quote Originally Posted by vectrapogo View Post
    Right, I see you mean
    Mileage : 000
    I have just bought some Optimum car wax spray.my intentions are to give the car a quick waxing to "top up" the Colinite 476s.
    Feb 2006
    Wirral
    What does this Collinite cost? Is it expensive?
  1. Spit and polish!
    By GARY3306 in forum Non Vectra C/Signum Album
    Last Post: 11th May 2011, 16:43
  2. anyody used showroom shine / spray and shine
    Last Post: 10th October 2009, 22:18
  3. spit shine
    By WKD-mcc in forum Quick Photo Album
    Last Post: 25th January 2009, 13:51
  4. Spit & Polish
    By Damian in forum Quick Photo Album
    Last Post: 10th April 2007, 18:15
  5. Spit Shining
    By AJA in forum Detailing and Car Care Discussion
    Last Post: 31st March 2006, 11:08
