Thread: EML light confusion?
    Apr 2012
    wolverhampton
    Default EML light confusion?
    hello guys/gals
    the other week i put HIDs in and in testing them with the air box off i turned the ignition, after putting it all back together my EML light was on? now is this because i turned ignition with air box off you think? I've left it a bit in hope the it would turn itself off and I've disconnected battery for a couple of hours but to no avail, could this mean I've knackered my AFM??
    helps appreciated folks
    thanks
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    What engine do you have? Is the car running ok?
    Assuming you disconnected the MAF Sensor, in order to improve access, the engine will have recorded this
    If the engine was started like this, then it would go into Safe Mode
    On reconnection and restart it will be a warning light only
    As I've mentioned before, remove the ignition key, wait about 30 minutes then restart
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    I did a similiar thing myself. Disconnect the battery for 20 minutes and when you reconnect it the EML light should be gone.
    Apr 2012
    wolverhampton
    its a 19.cdti 150, i have disconnted the battery and left it for 2 hours and light is still on? car is running fine so im still none the wiser??
    Quote Originally Posted by arry oudini View Post
    Sounds fine to me, the light simply confirms a fault has been recorded
    Once you have restarted the engine about 10 times or waited 48 hours the light will go out
    Regular Member 130786howe's Avatar
    Nov 2010
    wales
    it will be m.a.p sensor circuit mal function simply get code cleared and job done
  1. SMD confusion
    By MattVecVXR in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2013, 22:01
  2. Fog light confusion
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2012, 23:16
  3. Fog light confusion!
    By jagz21 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 13:00
  4. TID & GID confusion
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 18:28
  5. air box confusion!!!
    By littlesxi in forum Diesel Engine related
    Last Post: 7th February 2008, 09:29
