Results 1 to 10 of 11
Thread: foot brake issue
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    Default foot brake issue
    hey lads
    think ive got a minor problem with the foot brakes, 30 40 mph hit the brakes and all seems fine.
    70 80mph testing the brakes and different matter.
    if i hit the brakes hard im not lurched forward like i was in the 1.8 sri while i had it.
    with this 2.2 when breaking at high speed and watching the speedo the speed drops quite slowly with my foot pressing the pedal as hard as i can.
    you also have to push the pedal about a inch before you can feel the brakes starting to work.
    plenty of meat on the pads, but i aint sure about the discs, there seems to be more metal on the outside and lower rim of the disk, the middle of the discs aint as wide as the top and bottom if you know what i mean.
    if t he discs are worn too much would this cause the exces pedal movement before they kick in?
    as i say you whack the foot break but the car dont slow down as fast as i belive it should.
    passed mot only last week but that only means it met min requirements.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I would have thought from your description that the pads are not actually touching the disc across the discs entire surface,ie uneven wear .
    Personally I'd put new discs n pads in using quality aftermarket ones,unless you can get cheaper at trade. And I'b be checking the rears too,maybe even doing a brake fluid flush whilst access is good.
    Nov 2010
    East Midlands
    Trim : design
    Sound advice - definitely replace discs and pads for starters - do the fronts but examine the rears carefully and replace if necessary
    May 2012
    northumberland
    thanks for the replys, i will do the discs and pads all round and get the brake fluid changed, hope this will fix it, didnt feel good at all, pressing brake pedal hard but nothing much happening at the wheels in terms of slowing down.
    May 2012
    northumberland
    well i used eurocar parts for front and rear discs and pads, came to £84 thanks to 30% discount code someone posted on here (thank you lol) had them fitted today for free from the place i bought the car, straight away i noticed a vast improvement, just had to tap the brake pedel and i could feel the front brakes kicking in, just using brakes lightly till they bed in and dont wanna do a emegency stop from 70mph just yet lol, so hopefully once they bed in that should be the brake issue resolved.
    the garage has also identified one or two oil leakes, cant remember the exact places but some seals he said, not the rocker gasket i know that, so he wants my car for a full day next week to replace various seals all at his expense, engine bay is very clean and i cant see any oil just by looking, but i was getting a slight oil smell when stationary coming through the vents, so must be dripping on to exhaust or somewhere, i really cant fault the owner of the garage i bought this car he is wonderfull and nothing is a problem to him, real customer service and a joy to deal with.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    result id say..discount code?....gimmie gimmie...
    May 2012
    northumberland
    dp30 i think, if not its posted somewhere in this section mate, i think the code only applys to brake parts.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    is brakes im after...here goes
    Quote Originally Posted by 06sri
    The other one is MIDMONTH30
    May 2012
    northumberland
    it was dp30 for brakes, parts20 for a 20% discount on errrm parts lol
    make sure you check ebay as prices on ebay normally chepaest.
  1. Brake Fluid Leaking On to Foot Pedal
    By user999998 in forum Engine & Drivetrain
    Last Post: 12th May 2011, 13:27
  2. Vec B spongy brake issue
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2011, 23:35
  3. 2.0 Turbo Rear Brake Pad issue
    By a1ant in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2010, 20:54
  4. Brake Issue
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 20:38
  5. vectra cdti 150 brake issue
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2009, 13:18
