Thread: LED tail lights problem flashing strobe
    Jan 2012
    LONDON
    Default LED tail lights problem flashing strobe
    fitted my new LED'S tail lights and they look really nice,only problem is when I'm locking the car,the led,s flashing 30 seconds then stop. when I start engine and drive again flashing and never stop. Any idea please
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Bulb check system is causing it... there is no fix at present IIRC, are they all LED's or just the brake lights?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yep leds are no good for the vectra or siggy because of the canbus system
    Mar 2012
    Norway
    I think the Vectra C is using PWM to control the intensity of the lights since its using 21w bulbs on low power when driving and full power when braking, and I think the direct cause is too low switching frequency on the PWM in the car for LED's - LED's are way quicker to turn light on and off compared to an ordinary bulb.
    The flickering when driving should be fixed by an capacitor-circuit connected to the bulb, but I have not the knowledge to supply any info here. The flickering after the engine is stopped is probably as many says, the CANbus.
    But it amazes me that no one or no bulb-companies has figured a way to get around this problem, I have trouble to believe that Opel is the only make with this technology.
    Does it work on the Insignia?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    There is away around it with resistors
    Mar 2012
    Norway
    Do you get rid of both the flickering and the warning on the bulb check system with resistors?
  1. Would U fit Strobe Lights to ur car?
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 12:32
  2. help flashing interior lights
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 24th April 2010, 22:09
  3. i'm seeing flashing lights!!
    By jmcmil15 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2010, 17:47
  4. Flashing brake lights
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 20:51
https:www.vectra-c.comforumshowthread.php166837-LED-tail-lights-problem-flashing-strobe
tail light vectra c full led
i put led bulbs in my vectra c tail lights and they flicker
opel vektra 2007 strobo
led brake lights for vectra c
