Results 1 to 3 of 3
Thread: CDXi 3.2 Code 0340 - Camshaft Position Sensor Circuit Malfunction???
    Sep 2011
    New Zealand
    Default CDXi 3.2 Code 0340 - Camshaft Position Sensor Circuit Malfunction???
    Hi, I have 2003 3.2l CDXi with 135kms. Recently it started displaying a service "spanner" light on the dash and I get the code 0340 when I use the pedal /key method to check them. A quick search here points towards the Camshaft Position Sensor Circuit. I have been unable to find any info on the 3.2 specifically and would really appreciate some help before I wreck something!
    The car seems to run fine but has became harder to start. Sometimes the spanner light will go out after a few seconds and other times it stays on for 15-30mins.
    Are there any checks that can be done? I thought about taking it out and giving it a clean but couldn't tell which one it was so if anyone could point me towards the location of the sensor that would be great!
    Cheers.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    yes you need a new camshaft sensor the same happened to mine
    sorry the garage fitted mine
    Sep 2011
    New Zealand
    Thanks for the reply. I found the sensor, took it out and gave it a clean but the problem remains. I took it for drive and it has got worse with the check engine light staying on so I am off to track down a new sensor tomorrow.
  1. Y22dth po340 camshaft position sensor malfunction
    By GHz in forum Engine & Drivetrain
    Last Post: 5th January 2013, 21:06
  2. P0650 mil control circuit malfunction code
    By bobsimes in forum Troubleshooting
    Last Post: 5th July 2012, 22:17
  3. Replies: 4
    Last Post: 2nd October 2010, 14:58
  4. Fault code 0340 Cam sensor malfunction
    By otto in forum Engine & Drivetrain
    Last Post: 28th June 2010, 13:55
  5. O2 Sensor Circuit Malfunction
    By marcdale in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 21:21
