Thread: Brakes & Lambda sensor
    Jun 2012
    Edinburgh
    confused Brakes & Lambda sensor
    Hello!
    First off all sorry for posting here but in the "request a part number" section I am not allowed to post yet.
    1.) I just bought a 04 plate Signum 2.2 direct and I would like to change the brake pads and discs. I enquired onlne about them but I don't know the exact dimension of the disc or if I have or not sort susp.
    2.) I want to chenge also the lambda sensor because I know it is damaged but again how can I find wich one is it(front or rear) without going to a service?
    Maybe the questions are stupid but I hope someone will understand me .
    I am asking here because at the moment I live on one of the Scotish Island and it's a bit hard to get to a good service.
    Thank you very much!
    Jun 2012
    tamworth, staffs
    Best way to tell which discs are on it, take a wheel off and measure across the disc,
    The only way to find which sensor needs replacing is to have the codes read with a scanner.
    Jun 2012
    Edinburgh
    Quote Originally Posted by shadoweyes View Post
    thank you!
    It is hard because I don't have a scanner...and I don't have a service close to me unfortunately
    Jun 2012
    tamworth, staffs
    How do you know lambda sensor is damaged?
    Is there a light on the dashboard? If there is the probability is that its the rear one.
    May 2011
    bispham, blackpool
    Eml light will be on if you don't have a code reader do pedal test and count the flashes theirs a how to on here but on. My phone so can not do a link
    Sent from my HTC Wildfire using Forum Runner
    Jun 2012
    Edinburgh
    Quote Originally Posted by 6009tristanb View Post
    Yes, the light is on on the dashboard.
    I tried to make the pedal test but it seems I can't make it work .
    Jun 2012
    Edinburgh
    Jun 2012
    Edinburgh
    Yes, the light is on and sometimes the engine idle is uneven.
    And the guy that sold me the car told me that the lambda sensor is faulty. But he can't tell me if it is the rear or front one.
    Jun 2012
    Edinburgh
    I just ordered a code reader and I will find out in a few days
    Jun 2012
    Edinburgh
    Today the code reader arrived but unfortunately it's not working on my car. I ordered an U480...
    So...any ideas about how can I solve my problem?
    Thanks!
  1. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  2. Lambda Sensor
    By Cat_J in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 16:27
  3. lambda sensor again!
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:49
  4. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
  5. Lambda Sensor???
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2007, 22:57
