Results 1 to 10 of 11
Thread: Fittinf VX xenon headlights
    Hull
    Default Fittinf VX xenon headlights
    Hi guys
    Is there anyone around Hull area that know how to swap to standard headlights to the Vx xenon headlights??
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    if its prefacelift its not a problem facelift bit more difficult....
    Hull
    Quote Originally Posted by kenp View Post
    It is a prefacelift but i been reading the how to section and still dont fully understand what is needed to get the xenons working, i kind of understand about the leveling
    Engine : 2.2 Direct
    if the headlights are complet. then what you need to do to get them working is.
    Add 1 ground wire (can be done internaly there you need to join the ground wire) or externaly by adding a ground wire to the ballast thats below the headlight.
    Move your current headlight level motors over (remember to move them in highst position )
    Enable Xenon in the UEC.
    That will make them work. execpt the leveling is not automatic.
    Hull
    ok thats easy enough, ill have a go today thanks kenp
    Hull
    fitted the xenons tonight and they flicker, is this because i need to get them tech2 in or is it something else??
    Engine : 2.2 Direct
    Yes you need to have xenon activated in the UEC
    Hull
    i thought that they way that they wired up that you would by pass that?
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    Where in Hull are you buddy?
    Theres a place in Beverley i can recommend.
    Mike.
    Hull
    im in Beverley pal
  1. Xenon headlights
    By brod999 in forum General Chat
    Last Post: 21st November 2012, 19:12
  2. xenon headlights
    By tazdog03 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 20:02
  3. xenon headlights
    By denny321 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2012, 15:55
  4. Xenon headlights
    By Angel1368 in forum Styling
    Last Post: 8th May 2012, 11:25
