Results 1 to 10 of 19
Thread: Have I killed my clutch?
    May 2012
    Cambridge
    Default Have I killed my clutch?
    Hi guys,
    I bought an '03 2.0Dti a few weeks ago, 96k Miles. One of the first things I noticed after I got it home was that if I was even just resting my foot on the clutch pedal, it would slip under acceleration.
    No biggie I thought, just fully lift off when changing gears.
    Selecting gears is also a tad stiff, so yesterday I decided to spray a little 3-in-1 oil on the gear lever linkages on the top of the gear box.
    Now, today on the way to work, cruising at 70 in 5th, if I put my foot to the floor, the clutch slips. It's not done that before, however... and this is the big however...
    When I bought it, the vacuum hoses and one of the turbo hoses were split to ******y. I replaced them with silicone hoses and all was well, except the turbo hose from the intercooler had a bit of a kink in it because it was too long.
    Yesterday, when I oiled the linkages, I also shortened the turbo hose so it's not kinked any more. (Thereby possibly releasing the full power of the turbo?)
    So, I guess I'm asking, could the clutch have already been knackered, and I didn't notice it because of the split hoses/kinked pipe, or did my spraying 3-in-1 oil on the gear linkages seep into the clutch and ruin it?
    I've gotta drive it some more before I get paid, but once I have been paid, I could afford a whole new clutch, dmf, csc and fitting. I just don't want to.
    Any thoughts?
    May 2012
    Cambridge
    Sorry for the double post, couldn't find the edit button...
    But anyway, I've just had an online chat with Mr Clutch, and their rep quoted between £800 - 1000 for clutch kit and DMF, but only £329.99 without the DMF, including fitting and vat... I've screenshotted the chat so that when/if I pop in there, I have some evidence as 330 seems very cheap.
    Regular Member mspvxr's Avatar
    May 2007
    Chugging along
    Vehicle : Vxr in red
    God i wouldnt go to a Mr clutch again. Nicked my battery and swapped it for a duffa. Bunch of cowboys.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You rest your foot on the clutch?
    There is no point in just doing the clutch on its own considering your mileage you should really replace the DMF as well. It will not be long before that decides to go and you will have to replace the clutch again as it is likely to get damaged by a failing DMF.
    Also I think you have just found out why the previous owner got rid of it. Did you get it from a garage? If so you will be able to get them to pay out as the car is not fit for purpose.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    on 96000 miles this is about right for the dmf to play up
    do the whole kit it should cost about 650-800 depending on garages
    vauxhall i would say around 1600 pounds
    have a look a this thread
    http://www.vectra-c.com/forum/showth...-clutch-fitted
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by merikiito View Post
    Resting your foot on the clutch is the fastest way I know to burn the thrust bearing out.
    Jun 2012
    tamworth, staffs
    Dont know if anyone is aware of this, but there are clutch kits out there that convert a dmf to a normal flywheel. Have only ever got and fitted 1 to a 2.0 dti, but have done it to 2 vw's 1 skoda and a caddy van. There is no noticable difference once fitted apart from the price, think it was £140 for the kit.
    Spraying the linkages hasnt affected your clutch, rather it was on the way out when you got the car.
    May 2012
    Cambridge
    Bit of an update, been out for a drive today and the biting point has started getting lower and lower. It's now difficult to select gears. I'm assuming that when a clutch goes, it can go this quicky? Also, I should clarify, when I say rest foot on the clutch, I mean only while I'm accelerating through the gears, as in I don't totally lift my foot off, I just lift enough so that the clutch is engaged and my foot is simply resting on the pedal taking up the slack in preparation for changing gears.
    Given the above does this just seem like its given up the ghost due to high mileage?
    Jun 2012
    tamworth, staffs
    Biting point getting lower? Sounds like hydraulics. Is there a leak of fluid?
    May 2012
    Cambridge
    Quote Originally Posted by shadoweyes View Post
    Couldnt see one. Also, the brakes are fine. I'd expect a leak to mess with the brakes too.
  1. She Killed My Tool Box!
    By AdeV6 in forum The 'Off Topic' room
    Last Post: 5th July 2012, 20:37
  2. Has It Killed The Battery As Well
    By Si-SRI in forum Engine & Drivetrain
    Last Post: 4th August 2011, 21:30
  3. could have killed someone
    By jb-redbull in forum General Chat
    Last Post: 13th September 2010, 16:31
  4. Has your vec ever nearly killed you????
    By duncan2008 in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2009, 15:06
  5. I think I have just killed my car :(
    By v6diesel in forum Engine & Drivetrain
    Last Post: 11th December 2008, 00:23
