Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Thermostat/Temperature Question
    Jun 2012
    Scotland
    Default Thermostat/Temperature Question
    Apologies for yet another thermostat thread (been searching forum trying to find a similar situation with no luck)
    Have a Vectra 1.9CDTi 120 and it had the standard issue of not heating up when driven at speed (was heating eventually when crawling around town).
    Being that i've only had the car a couple weeks the garage that sold it took it in and replaced the thermostat, now it seemingly heats up better but the temp gauge still drops right back to the bottom on longer runs/higher speeds.
    The actual heating is perfectly fine and on full heat the interior is insanely warm therefore the garage thinks theres nothing to worry about.
    However, on looking through most of the temperature related threads on here everyone seems to talk as if the guage should go between 80 and 90 and stay there no matter the distance/speed.
    Thoughts and/or reassurances would be welcome
    Cheers.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    from what you wrote above this is not right the needle should stay around 80- 90 and stay there
    it does not go flat to the bottom again on the gauge
    i changed my thermostat this is how i know
    May 2006
    scotland
    I replaced my thermostat (150) and generally it stays around the 85 mark. However, and I think the following is perfectly normal and expected, when I turn the heater control fully hot and put the heater fan on speed 3 or 4 and the car is cruising down a hill for a while, then the temp drops a wee bit. I have seen it go as low as 78.
    Similarly, when stuck in traffic, I have seen it rise to low 90s before fans kick in.
    I do not think it should go down to 70 or below though as yours appears to do. Maybe the water pump is not working as efficient as it should be.
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Doesn't sound right to me, take it back to the garage, doesn't sound like they've replaced the stat, maybe done a temp fix hoping that will make the problem go away. My car took ages to get to 85-90 and when it did the needle was still all over the place going back down to nothing and back up again and down when i had a little speed, this was fixed when the stat was replaced, now it gets to temp in under 10 mins and stays there no matter what speed i'm doing. Go back and have them show you where the new stat is, if it's new it will be nice and shiny. They're pulling a fast one, prob took one out of another motor.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by wickedwillie View Post
    spot on
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by CH-VECTRA-ELITE View Post
    again spot on
    Feb 2011
    Selby
    I don't know about the 1.9CDTi engine, but certainly on the Z18XE (1.8 petrol) engine, whilst it's possible and cheaper to change just the thermostat, there's a reason Vauxhall only supply the thermostat complete with a new housing. I replaced just the stat on mine, and it was fine for a few months (temp around 85C all the time), it failed again. I decided to replace the housing as well this time, so got a genuine GM one. It's been fine ever since.
    Examining the old housing revealed that a groove had been worn in the housing by the brass disc of the thermostat, meaning that it couldn't seal properly. So if this is true of the 1.9CDTi as well, I'd get them to do the job properly - ie fit a full housing as Vauxhall recommend, not cut corners by fitting a new stat in an old housing.
    Jun 2012
    Scotland
    Cheers for the replies. Gonna have to consider taking it back up with the Garage.
    Anyone able to point me to a picture or a really good description of where the theremostat is on the 120bhp engines so i can have a bit more ammo when i chase them up?
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by Kaput View Post
    Your better off looking at the how 2 on here that will describe it and with pics aswel even though its for the (150) its in the same place on the (120) mate
    Nov 2010
    East Midlands
    Trim : design
    Smile
    Quote Originally Posted by rich r View Post
    On the 120 /150 you have to replace the whole housing and the coolant temp sensor - the 150 is easy - the 120 is a bit more challenging - which is why they probably haven't changed it
  1. Temperature gauge after thermostat change
    By Swanni in forum Engine & Drivetrain
    Last Post: 4th January 2013, 10:52
  2. thermostat for z19dth , a wee question
    By simplesi in forum Engine & Drivetrain
    Last Post: 18th October 2012, 01:19
  3. another thermostat question
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 11:22
  4. Question...thermostat removall
    By Maxim007 in forum Engine & Drivetrain
    Last Post: 9th September 2009, 21:22
  5. Temperature Gauge question
    By silvermachine in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 15:37
06 vectra 1.9 cdti 120bhp temp gauge not rising
coolant gauge reading low vectra c
Vauxhall vectra cdti 120bhp www.vectra-c.com
vectra c 1.9 cdti thermostat GM
vectra c cabin temp controller
vauxhall vectra 1.9 cdti temperature reading varies
vectra 1.9 cdti temperature selector
