Thread: Redex diesel cleaner
    Jun 2012
    essex
    Default Redex diesel cleaner
    i have been racking my brains out my SIGNUM 2.0 DIESEL is smoking continualy
    i have checks the egr valve and also any splits to pipe work and also the tps all fine
    i used redex diesel cleaner could it make it smoke ?? any idea would be very greatful
    Redex raises the cetane level, it will not cause an increase in smoke
    However, as with all third party additives you need to use it for at least four full tanks to notice any change
    An alternative is to use a premium fuel and compare
    If there is no change then it is a mechanical issue
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by signum_05 View Post
    Id start by checking the condition of your air filter as it is the easiest and cheap to replace also try giving your maf sensor a clean with isopropynol alcohol as when these get dirty or start failing they cause fueling issues
    Jun 2012
    essex
    many thanks for your replys i have checked the air filter looks go as new and im going to give the maf sensor a clean as soon as i got sum isopropynol alcohol but that could be the reason my TPS is giving a high imput many thanks
  1. Redex 0 to 60 Diesel
    By John Bishop in forum General Motoring Chat
    Last Post: 18th April 2012, 23:40
  2. Redex or similar injector cleaner
    By RobW in forum Engine & Drivetrain
    Last Post: 14th January 2011, 15:43
  3. Redex, (diesel) any good? what benefits?
    By Andy17899 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 13:33
  4. Diesel cleaner!!
    By ACE.TAG in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2007, 17:22
  5. Redex Diesel
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2006, 23:10
