Results 1 to 10 of 14
Thread: Very odd noise
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Default Very odd noise
    January this year I had a new DMF & clutch fitted to the car and have covered approx 8k since then.
    Over the past few weeks I have noted that when the car is started from warm \ hot with the clutch in there is a noise but starting from cold nothing.
    Today, I called off at my parents after driving 35miles from work. Went back out to start the car and there was a very loud clattering noise coming from the car, it eventually cut out. Started the car up again and it was fine.
    There are no fault codes but I don't believe it's anything with the engine \ electrics.
    It sounds to me like the DMF is falling apart again
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    doe's the cluth pedal feel any different from when it was fitted,was a new thrust bearing fitted at the same time as the cluth assembley
    Aug 2010
    Pontefract
    its funny you say that but sometimes the clutch pedel feels different between each journey, I thought that this was just my imagination.
    I'm not sure about thrust bearing, just had a look at the receipt and it just says "Clutch unit & flywheel"
    Are these symptoms related to a thrust bearing? It's worring that the car made this clattering sound and then cut out after starting, while it was clattering the car semt to be struggle to idle.
    I've done a bit of reading and some people mention timing belt but since this the car runs fine, pulls like a train, no smoke etc. just the usual noise can be heard when starting from warm which i think is linked somehow.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    when i asked about a clutch change they said when you have it fitted after so many miles they said bring it back for a check
    so i would do that
    how many miles has the car done?
    have you had a cambelt and waterpump change?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    maybe related have a read
    http://www.vectra-c.com/forum/showth...6v-CDTi-owners
    have a read of post 5
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    also check engine mounting bolts
    Aug 2010
    Pontefract
    thanks for the pointers Vectra ste, I'm going to go back to where the clutch was done tomorrow with it and let them have a look.
    the strange thing is that this noise only occurs when the car has been run and is up to temp and only when started...
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    Quote Originally Posted by damers2000 View Post
    i see it doesnt sound a bad as post 5 then
    at least you have a warranty to check the clutch
    Aug 2010
    Pontefract
    just been down to the garage and they have diagnosed it as a starter motor issue, new starter fitted £325......... WOW
    I think I may just put up with the noise for the time being
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    wow wow 325 pounds
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
