Thread: Vectra C Turbo
    Jun 2012
    Northampton
    Lightbulb Vectra C Turbo
    Hi i Have a vauxhall vectra C 2.0 Litre turbo 2003. I was told i can get my turbo power increased with a turbo boost controller. What is the recommended boost bar i can increase it to without blowing my turbo?? lol can any one help??
    Ryan
    South east
    I think you should take a look at remaps rather than try altering the boost by another method. These companies can all help:
    www.torquingbhp.co.uk
    http://www.maptun.com/tuningGuide.ph...56&listorder=5
    http://www.bsruk.co.uk/
    www.superchips.co.uk
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    on these engine a boost controller is not worth it, its more than likely going to put your car into limp mode as the ecu will not like figures its gets back from the boost solenoid, and yes I have tried one on mine...
    best option is as advised above, a remap will get loads more out of your engine..
    Jun 2012
    Northampton
    Many thanks for your help people.
    Yer i think remapping is my best safest bet because if i get that boost controller i am worried i might blow the turbo.
    I took my car to a performance garage and they told me im already getting less power than im suppose to because i still have my original air filter box on is that true??
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    well.... if you change the airfilter to a high flow panel filter like a Pipercross or K&N you will do better, removing the half funnel from the bottom of the airbox helps a little, don't remove the trumpet section from the top of the airbox as that will create airbox turbulence and give you MAF errors... Some guys use cone filters, i tried a BSR one and could not stand the noise (personal choice), it did nothing performance wise over a modded airbox though.
    Jun 2012
    Northampton
    Thanx when you say noise what kind of noise was it making a sporting noise??
    Jun 2012
    Northampton
    and also which one would give me the most power a panel air filter or a cone air filter??
    11 Post(s)
    Hi, and welcome.
    No offence mate, but you'd be far better off asking your question in a more populated area of the forum that's meant for this type of question.
    This part of the forum is called "introduce yourself" and the title should be self explanatory.
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    the noise is what you would refer to as an air induction noise, its the sound of the air being sucked throughh the air filter, with a cone filter it will sound more throaty and louder than with a modified airbox. As for one over the other i found no extra performance between a cone and 'modified' airbox.
  1. Vectra 2.0 turbo
    By FIL 4822 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 25th January 2009, 10:07
  2. Vectra 2.0 Turbo
    By Jonil88 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 17:05
  3. 2.2 Vectra C Turbo .....
    By Bainie in forum Petrol Engine related
    Last Post: 9th March 2007, 15:24
