Results 1 to 3 of 3
Thread: Folding mirror / Passenger window issue
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default Folding mirror / Passenger window issue
    AFternoon all,
    Ever since I fitted my folding mirrors and had them tech 2'd the passenger window has only worked from the drivers door.
    I am currently getting the following errors
    B2966-05 Driver doorknob circuit open
    B3844-05 Passenger Door switch window lifter circuit open (I presume this is my problem)
    Can anyone suggest what needs to be done to fix it?
    Thank you in advance
    Stephen
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    right......
    i assume you changed the PDM? if so you need to check the setting for the door switch it can be set to facelift/prefacelift mode...
    if set to preface mode on a facelift the window switch wont work..
    as for the other code ignore it its the DDM looking for an electrical lock connector, i have the same thing on mine.. think the option on the DDM on that one is 'electrical lock switch' present/not present... setting that to not present should cure it i think.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Cheers mate I'll get some on with tech 2 to have another look
  1. To swap auto folding passenger door mirror
    By Ziggy in forum Parts for sale
    Last Post: 24th July 2009, 08:47
