Thread: Happy Light Show problems
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Default Happy Light Show problems
    Is my diagnostic socket, under the ashtray, the correct way up??
    On mine Pin 1 appears to be the last pin on the bottom row?
    I know the pic is not very clear, but the socket has the slightly narrower part at the top.
    Regular Member ollie {150}'s Avatar
    Jul 2010
    birmingham
    I had the same problem with mine mate I just turned the happylightshow upside down worked fine
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    yup the instructions are wrong.
    Can you do me a favour please once you have it installed. I have asked this a few times, but so far no one has checked.
    Once you have it installed and your engine running, can you indicate right with your foot on the brake (as if you were waiting to turn / slowing down to turn) and then flash your lights (as if to tell someone to go).
    Stephen
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    I had the same problem with mine mate I just turned the happylightshow upside down worked fine.
    Thanks, thats what I thought. It didnt work at all the 'right' way up, I have now fitted it up-side-down (and at a slight angle, maybe one of the pins was not in the socket) and it works a lot better. Not got the full hang of it yet, it is still doing mad things.
    The doors lock after moving off, but dont unlock when the key is removed, so it is probably on Speedlock 2.
    It also has a 3rd LED, an amber one, lit when driving.
    I also had the light switch set to Auto instead of Off, as stated in the instructions, so I need to have a play it with it with the light switch off.
    Yes, tried that, it seems to put it in setup/programming mode for the 'Lightshow', it seems to be covered on page 9 of the online instructions, but I'm not sure if the Lightshow is separate thing or part of the WTCC.
    http://www.happylightshow.de/English...a%20Rev1.0.pdf
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Quote Originally Posted by TonyP2020 View Post
    Cheers mate. That's what mine does but everyone else said it should only do it when the engine is off
    Events Manager & Moderator jon1.9cdti's Avatar
    Swanley , Kent
    125 Post(s)
    Vehicle : Sports Tourer
    Engine : A20DTH
    Year : 2010
    Mileage : 201000
    Quote Originally Posted by s_zigmond View Post
    with my happy light show i can activate the happylightshow with the engine running, it switches off as soon as you pull away
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    well after a few days use I am still not happy with the HLS. It does not seem to be making proper contact with the OBD socket, the green light keeps going out. I have still not got it set up right, and it is still doing daft things.
    So now I'm after a dead op-com interface (NO Software) so i can see if i can use the plug part to mount the HLS on so it makes better contact with the OBD socket.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    I have now given up with the HLS. Rich at Vectra-C spares has given me a full refund, including postage, which is very generous of him.
    He has said I can just bin the HLS, but I am going to ask Rich again if he wants it back.
    If he doesnt want it back, then I am happy to post it to a regular member on here to see if he/she can get any sense out of it.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    HLS now posted to Hairy31. It will be interesting to get some feedback on it.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Tony as pm..........thanks for sending this, unfortunately it doesnt appear to communicate with car very well, starts to program then seems to loose connection. I have a contact through work who is an electronics engineer (works for pace - who make sat boxes etc etc) and he is gonna take a quick look at circuitry to see if any probs with joints etc. will keep you posted . and thanks again
  1. Happy Light Show Problems
    By TonyP2020 in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2012, 18:18
  2. For Sale: Happy Light Show
    By weverall in forum Parts for sale
    Last Post: 8th March 2012, 17:10
  3. happy light show
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2011, 23:50
setting up vectra happy light show
happy light show forum
how to activate happylight opel
happy light show vectra c
