Thread: Diesel injector seals failed after 18 months!!!
    Regular Member ads3's Avatar
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    Default Diesel injector seals failed after 18 months!!!
    Hi,
    Have been told by VX that my injector seals need replacing and this is what caused the Veccy (05 2.0dti) to not start 2 mornings ago. Green Flag came out and ended up squirting some carb cleaner into the airflow meter after disconnecting it from the air intake duct. Started fine afterwoods and has done ever since.
    I only had these seals replaced (or so I was told as there was oil in the fuel line) 18 months ago when I had the diesel pump replaced. Surely these should last longer, especially as I have been told it's about a 5 hour job.
    Should I have any reason to question the diagnosis?
    Any suggestions and tips greatly appreciated.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Who did the seals 18 months ago (were they definitely done) ?
    Is there oil present in the fuel filter/housing ?
    Have the fuel filter seals been replaced ?
    Have the injector spill pipes (small braided/rubber pipes) been replaced ?
    All the above can leak air into the fuel system, usually overnight, causing bad/non starting issues.
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    5 hours to replace injector seals?
    May 2011
    South London
    My workshop
    1 hour 15 mins
    Copper seals £ 1.56 each
    Rubber seals £ 8.45 each
    Fuel filter £ 11.80
    Labour £ 55.00
    Plus vat @ 20%
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    Thanks,
    Apparently 5 hours to change all the seals!
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    Quote Originally Posted by C-Owner View Post
    It was done at the same dealer, they are going to look into it.
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    Does the addition of 2 stroke oil in the fuel system perish the seals more rapidly?
    Northants
    Engine : 2.0 DTI
    Mileage : 86,000
    In addition to the injector seals - quoted £515, I have also been told that the EGR valve needs replacing at £503 ??????
    Do these prices sound about right?
    East Ayrshire
    Trim : SRI XP1
    Unsure about the seals, but the egr valve is about £90 from VX and takes 15mins to change
  1. injector seals
    By chris1804 in forum Engine & Drivetrain
    Last Post: 21st September 2011, 17:07
  2. Injector seals
    By suggs1971 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2010, 09:48
  3. Injector seals
    By suggs1971 in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 22:02
  4. Injector seals!!
    By siz1 in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:20
  5. injector seals
    By tditony in forum Vectra C / Signum Troubleshooting
    Last Post: 6th May 2009, 20:10
