Thread: More fault codes 2.0dti
    Feb 2012
    Uxbridge
    Default More fault codes 2.0dti
    Hi guys, iv had a few issues with my 05 preface 2.0dti signum. The latest is the MAF sensor, I replaced it with one off ebay and the problem remained so I assumed that it was just a dodgy flea-bay effort. Iv just shelled out 120 quid on a brand new one and the problem is still there. When i plug in opcom it comes up with error code p0100-66 performance and range fault.
    Has any body got experience in this and what is the fix because it cant be the MAF sensor itself as I've been through 3 and the fault code is still the same.
    Cheers,
    Ed
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It could be worth removing, cleaning (WD40, plusgas, IPA Solvent) and refitting all electrical connectors in and around the engine bay. Most of them just unclip, and are not hard to get at.
    Also the Atmospheric sensor is linked with the MAF sensor, it is near the airbox, and can have a problem with dirty earthing, so again cleaning connectors is worth a go, especially if get any p0110 errors.
    Good luck.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    check for any air leaks , split pipes etc .
    the problem being range / performance means that the ecu is getting a lower signal of air passing the sensor than it expects to see , this can be caused by an air leak on the intake side , have a good look at the boost hoses .
    Feb 2012
    Uxbridge
    Thanks chaps, all much appreciated, will have a good look when I get back home. Iv had to resort to my old 206.
  1. help needed to fault find (or read codes) 2.0DTi
    By FLOB in forum South East (RO - Scotty80, ARO jaqubek)
    Last Post: 4th April 2012, 18:15
  2. fault codes
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 18:41
  3. 2.0DTi Fault Codes
    By martint in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2011, 14:14
  4. Help with Fault codes
    By Rhbjones in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2010, 13:08
vectra c 2.0dti air mass meter faults www.vectra-c.com
