Thread: Will a Unprogrammed cim work?
    Regular Member krazylegz's Avatar
    South Shields
    Default Will a Unprogrammed cim work?
    As above my cruise control problem still persists, cutting off when it wants too.
    I've changed the clutch and brake switch and tried 4 different stalks so I can only put it down to the CIM as sometimes it cuts off if I indicate or use steering controls.
    If I get one from the scrappy.... Risky I know bye I don't want to spend £200+ on one from vauxhall if it may not be that. If I plug it straight in will the indicators and wipers still work until I get it programmed to the car?
    Sent from my iPhone using my fingers n thumbs
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It will be coded to the doner car so you will need the code from the breakers you will also need to program it to your car before it will go anywhere as the CIM has the immobiliser in it and is the centre of the majority of your cars communications system. Ensure you also get one with the right ident for your car. So no it wont work with your motor straight of fit will 't work until programmed into your car.
    South Shields
    Ok thanks mate, so I need one that the car has the security pass available?
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Simplifying it no.... Either get cleared or one with code whatever u do tech2 is essential as u need ur keys programmed as well so tech2 not vaux.com or the likes ....
    South Shields
    Ok do just to be 100%, if I get one from scrappy what code do I need for it to be reset? The car security pass? Failing that there is some on the bay already reset or with the codes
    36 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by krazylegz View Post
    Correct u need car pass from donor car ....
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. little bit of work done
    By VectraElite 2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 22:34
  3. To work or not to work that is the question
    By garvey in forum The 'Off Topic' room
    Last Post: 31st December 2008, 19:02
  4. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
  5. Anyone else still at work...?
    By izonoky in forum General Chat
    Last Post: 24th December 2007, 13:35
