Results 1 to 10 of 13
Thread: ERROR CODES signum 2.0 diesel
    Jun 2012
    essex
    Default ERROR CODES signum 2.0 diesel
    hiya
    just brought a signum 2.0 diesel 2nd day of having it went lumpy and went in to limb home mode then the problem solved its self now very heavy sotty black smoke is continuly coming from the car. took it to the garage today and got the codes P0638 twice and P0070 can any one help sovle this problem many thanks
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    P0070 is your ambient air temperature sensor this sits at the bottom of your front lower grill , just check the connection,s . Now this is electrically connected to your TPS Throttle position sensor p0638 is related to this problem
    East Midlands
    Check egr valve,and give it a clean look for how to on here.
    Engine : 2.0DTi
    Mileage : 73350
    Quote Originally Posted by bobssignum View Post
    Firstly is your temp sensor giving you an accurate reading example today,s temp around 20-24 degrees .
    If the sensor is not giving accurate readings then check out the connection,s or replace sensor, fairly cheap on e bay .
    p0638 can be generated by a few things
    1 faulty tps sensor ,
    2 leak in vacuum hose,s leading to manifold vacuum unit,
    3 sticking butterfly valve in inlet manifold
    with the first two being the more common faults .
    Regular Member recoveryman's Avatar
    glasgow
    Vehicle : vectra
    Trim : elite
    Engine : 1.8 petrol
    Mileage : 92000
    Generic OBD Error Code Details for P0638
    Throttle Actuator Control Range/Performance
    What does this mean?
    OBD Code P0638refers to
    The Powertrain Control Module (PCM) compares the actual Throttle Possition (TP) with the target TP when the engine is running. If the difference is more than the specification, the PCM determines that there is a throttle actuator control circuit range/performance problem.
    Symptoms
    Possible sumptoms of OBD code P0638
    - Engine Light ON (or Service Engine Soon Warning Light)
    Causes
    Possible causes of OBD code P0638
    - Drive-by-wire control system malfunction - Throttle actuator malfunction - Throttle valve malfunction - PCM malfunction
    Jun 2012
    essex
    thank you for the replys will be working on the car today to try and get the problems sovled and is there any one who could post the link for the egr valve cleaning page due to i cant find it cheers all
    Engine : 2.0DTi
    Mileage : 73350
    You should find your link here plus a whole load more info
    http://www.vectra-c.com/forum/showth...w+2+egr+2.0dti
    Jun 2012
    essex
    cheers for that i have taken the egr valve gave it a good clean but hasnt solve the smoking problem also i have checked the tem in the car and was reading 22 today so i dont see no problem with that also dont seem to be any holes in the pipe work at all so im a bit stuck only other thing is the tps any idea where it is located so i can check that over cheers
    Engine : 2.0DTi
    Mileage : 73350
    Tps can be in one of two places on the 2.0DTi .
    It is either on the inlet manifold itself as in the above pic The square looking sensor directly in front of the oil filler cap, or on some Dti it is actually on the throttle pedal itself.
    NOTE If the first one then -Do not take the tps sensor off the manifold itself .
    this has a collar inside the butterfly which if wrongly alligned on refitting can be easily broken
    Vauxhall dont sell the sensors seperately you have to buy the whole upper manifold .
    Vx charge to get a replacement £340
    though you can get them on the online vx deals for around £100 less . So best left alone .
    Jun 2012
    essex
    oh really is there no way my one can be fixed or what not coz dont really fancy forking out £340 lol because that can be the only problem from now cheers bobssignum
  1. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  2. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  3. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
  4. Error codes, 2.2
    By Rennie in forum Engine & Drivetrain
    Last Post: 10th April 2010, 23:21
  5. Help With error CODES...!!??
    By sheiky in forum Engine & Drivetrain
    Last Post: 26th July 2007, 11:30
