Thread: 245/35/19 what tyre pressures to use now?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Question 245/35/19 what tyre pressures to use now?
    Hi guys. I've got my new tyres on, but now that I've got a wider profile I don't know what tyre pressures to keep them at? What would be your recommendations? & what are people running on?
    Engine : 1.9 CDTi
    I run mine at 41 psi
    Regular Member coldo's Avatar
    Scotland
    I would have said arround 38 PSI going on the basis that you double the wheel size to get teh presure to be used
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    double the rim size and add 2psi and you wont be far wrong
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I run 38 in mine but there 235/35/19
    New Member a wet monk's Avatar
    Newcastle-under-Lyme
    This is a straight forward question...
    Vauxhall specify for 235/35/19:
    Front = 38
    Rear = 33
    Here's the thing - psi stands for pounds per square inch and therefore we're talking about something that has no relation to the volume of the tyre. You could double the width of the tyre and it would still run best at the above pressures ^_^
    Quote Originally Posted by paulvectrac View Post
    I would advise that running 38 all round is a bad idea. I don't know how you drive, but if you're like me and every drive into work is like a session at silverstone then you should reduce the air in the rear to 33 as even vauxhall accepted that our cars were awful at cornering. The lower pressure will make sure you don't find yourself looking in the direction you came from everytime you try to 'let off stream' on a country Lane!
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Thanks for all the replies guys. Much appreciated.
    *steam
    Engine : 1.9 CDTi
    Pretty sure autodata says 41 psi
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
what tyre pressure do you put in a vectra size 23535zr19
24535zr19 tyre pressure
245 30 19 vectra vxr
vectra C tyre pressure 19 inch rims
vectra vxr 245 tyre
24535r19 tyre pressure
