Thread: 1.9CDTI (120) Hesitating / Miss Fire
    Nov 2009
    West Midlands
    Unhappy 1.9CDTI (120) Hesitating / Miss Fire
    Hi all,
    Just had an EGR valve replaced on my SRI 1.9CDTI 120 and ever since it has developed a sort of hesitation when warm and between 2k-3k revs.
    I took it into the local Vauxhall garage today and they have stated it is a carbon build up on the valves and will cost over £800 to fix!!!
    I have read on this forum that you can remove the EGR valve and block it and then get the engine remapped but when I asked at the dealer if this would fix the problem I was told the car was "too clever" and this wouldn't work.
    Anyone got any suggestions as really don't want to spend this sort of money.
    Thanks.
    Pete.
    Regular Member johp778's Avatar
    Apr 2012
    Leeds, W Yorks
    Hi
    You can get the EGR blocked and mapped out, there are many threads on here about the DPF and EGR valve and many members have already done this. There is a company in Keighley who can do it, http://www.masperformance.co.uk/, they quoted me £350 to blank and map out EGR and remove my DPF, maybe worth giving them a call, but you should also be able to find threds about it.
    You could also try a product called BG244 to clean some of the carbon out, It was recommended to me, so I have already done it on mine, although I'm having no problems at mo.
    Apr 2012
    Leeds, W Yorks
    West
    Carbon build up on the valves... have you tried some fuel system trreatment & a good thrapping down the motorway.
    May 2006
    scotland
    Do a trial EGR blank. Very simply, disconnect the electrical connector (if the 120 has one) then take the car for a test drive (eml and spanner lights will follow but these will clear after a period of normal connected EGR driving resumes or clear the codes with a code reader).
    If that solves your problems then you have a choice, either leave it disconnected (costing you nothing) or blank and get it remapped out. In this scenario, I would take the former option for sure.
    It could also be an air leak introduced when the EGR was fitted.
  1. Miss fire at 1500rpm on my 120 cdti
    By rob10 in forum Diesel Engine related
    Last Post: 29th June 2013, 23:37
  2. Vectra sxi 1.8 16v won't rev. Miss fire. Helpp
    By Arran1993 in forum Engine & Drivetrain
    Last Post: 31st October 2012, 19:49
  3. vec b miss fire
    By daddyjay in forum Engine & Drivetrain
    Last Post: 25th September 2011, 19:26
  4. miss-fire on vec c 1.9cdti 150bhp
    By bridge_eee in forum Engine & Drivetrain
    Last Post: 25th October 2010, 12:54
  5. Miss Fire has gone!
    By Maverick in forum Diesel Engine related
    Last Post: 12th June 2009, 09:02
