Thread: Key fob not letting engine start
    Maidstone, Kent
    Engine : 3.0 CDTI 184
    Cool Key fob not letting engine start
    Hi Guys,
    I have 2 keys, both lock & unlock the car perfectly, 1 starts the car first time every time, the other keeps coming up with a spanner symbol & doesn't let the engine start.
    1 Key is the original type that you got on an '03' plate & the other is a new shape key (like you get on an '07' plate), the new shape key has the correct electronics/chip inside & I've even swapped the chip board from the old zapper to the new shape zapper & the new zapper still only works intermittently.
    I have replaced the zapper batteries & that doesn't make any difference, I heard about a design fault with the key fobs & that the main dealers stuck bits on cardboard in the key fobs but really need a reliable answer.
    Please help !
    Admin plasma's Avatar
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    the transponder doesnt rely on a battery voltage, it gets its power to send the transponder signal by being placed near the receiver (something to do with a voltage being created by passing a winding of coils near a magnet induces a voltage) so it looks like the transponder/key itself mate.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Maidstone, Kent
    Thanks Plasma, the circuit board doesn't seem to sit in the new key very solidly so I think you are right, I'm going to try jamming some cardboard inside the key fob & I'll see if I can come up with some useful info for anyone else with the same problem, cheers !
    Maidstone, Kent
    I worked out what was wrong ! You were absolutely right Plasma, the coil that creates the signal is actually a spring !
    On the newer keys (with the little button you press & the key pops out) you have to turn the spring round by force 3 times so that when you press the button the key pops out easily, it also compresses the spring & makes it contact the right bits, I tried it over & over again to make sure it was reliable & it has been perfect, cheers for your help Plasma !
    On the Forum
    335 Post(s)
    Engine : 150
    Mileage : 74000
    not strictly what i meant but glad it prompted you to look at what you did and fix it.. well done matey
  1. Engine and Spanner Light Before I Start The Engine
    By corderz in forum Engine & Drivetrain
    Last Post: 24th March 2011, 18:48
  2. Engine wont start
    By frag45 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2010, 17:16
  3. Few engine trembling when first start
    By Lao in forum Engine & Drivetrain
    Last Post: 18th March 2010, 18:10
  4. 1.9 CDTI (150) Engine won't start
    By koolrunner in forum Engine & Drivetrain
    Last Post: 20th April 2008, 11:04
